Old 03-13-2008, 13:02   #1 (permalink)
knok95's Avatar
Member: 151175
Sonork: 105497
Thanks Meter: 98
about infinity
infinity is best .
for chinese mobiles infinity pin finder is not good for example i tried with chinese nokia n95 working mobile it was not detecting
that mc tool was connecting with in max 15 seconds time so i think mc tool is best for chinamobiles in my experience
Old 03-13-2008, 13:46   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
hi,
so i think you have a little experience with 30 posts;
you need more experiences
br
Old 03-13-2008, 14:24   #3 (permalink)
knok95's Avatar
Member: 151175
Sonork: 105497
Thanks Meter: 98
reply to this error mr.zinoubinabil
software version: 1.06
cable type: 2x6 (L12B)
platform: MT62xx (autodetect)
searching adapter at COM4...
adapter found, version: 2000
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200
19200
failed to detect pins
time required: 63 sec
Power Off !
Old 03-13-2008, 14:52   #4 (permalink)
traxgsm's Avatar
Member: 636518
Thanks Meter: 175
strange post
hi friend stop please ..ther is no way to compare between mctool and infinity..olso it is strange that you have problem in n95
Old 03-13-2008, 15:00   #5 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
@knok95
plz check this link & see how many testes report with seccess
http:///vbb/...d.php?t=499829
ps: check your phone connector
br
Old 03-13-2008, 15:06   #6 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,569
pins: 12, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200
19200
Power Off !
check this link too & read it carefully
http://www.infinity-box.biz/download..._PinFinder.pdf
Automatic pinout detection: Troubleshooting
If you have any problems with Rx/Tx pins detection, please, follow the next steps:
1. Be sure that you have connected “Power” wires correctly (see previous chapters for detailed information
about power cable connection)
2. Be sure that cable connector inserted inside phone connector completely
3. Be sure that phone bottom connector contacts is clean. Please, clear phone connector contacts if it's
required.
4. Be sure that phone bottom contacts is not damaged inside connector.
5. Be sure that phone bottom connector well soldered to phone PCB (need to open phone and check it)
6. Be sure that phone bottom connector contacts not cutted internally (need to open phone and check it)
7. Be sure that phone has Rx and Tx pins on phone bottom connector. Some phones don't have Rx and Tx
pins on bottom connector but has Rx/Tx test-points directly on phone PCB.
8. Some cables from dufferent manufacturers may have additional wire that should be cutted for correct
detection results. See picture below and cut wire according to marks on picture.
If you are sure that you have checked all above steps and you are sure that the problem is with
PinFinder configuration, you can modify PinFinder confiruration for best results. Default PinFinder configuration
values was tested with many phones and found quite good (optimal values for good detection/performance
results), but sometims you can try to change default values: it may be useful if pinout detection results was
incorrect or it's impossible to detect Rx and Tx pins at all.
Old 03-13-2008, 15:31   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@knok95
We have prepared mega detailed user manual with pictures and step-by-step instructions.
I am sure that no any other product has so detailed, so easy to understand and user friendly manual.
Please, read manual in case of any problems.
If you don't know where to start please, start from reading:
1. download http://www.infinity-box.biz/download..._PinFinder.pdf
2. read something
3. read page 18: Automatic pinout detection: Troubleshooting and for sure you will get an answer
Old 03-13-2008, 17:35   #8 (permalink)
EMOTION BBSR's Avatar
Member: 194285
Thanks Meter: 53
The Best Box, The Best Support, The Best Team
And Will Remain THE Best Forever
Old 03-13-2008, 18:00   #9 (permalink)
Member: 162536
Thanks Meter: 5
infinity is best .
Please, INFINITY is the ONLY product that gives free TUTORIALS and ULTRA QUICK RESPONSE to all problems. If you don't understand any thing ASK. Do not compare charcoal(mcTool ) to DIAMONDS (AUTO PINFIDER ADAPTER). It will be better and advisable for you to go to the so call MCTOOL site to praise them than to come INFINITY site to misbehave. INFINITY IS THE BEST TECHNOLOGY THINK TANK. Greetings from Ghana.
Raneric
Old 03-17-2008, 12:55   #10 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
pins: 12, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200
19200
Power Off !
hi knok 95 if u have this probleme just in chinese miracle 100/100 fdi probleme
change fdi module and u see this problem existe only in slim infinity i have
this problem i change the fdi and the box conecte to the mobile in 10s
What About Infinity-Box.org Support area Amir-SkillZ Infinity-Box 3 01-12-2009 18:17
about infinity-box.org and infinity-box.com?? tshcom Infinity-Box 3 12-04-2007 08:07
Urgent Support about infinity problems !! humbedj Infinity-Box 1 02-17-2007 08:36
a38 now add to vygis what about infinity box elsamady Infinity-Box 2 12-12-2006 06:10
About Infinity future... luskao Infinity-Box 5 08-30-2005 08:28
Page generated in 0.21549 seconds with 9 queries
