Old 11-01-2007, 10:42   #1 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
KG275 unlock but
COM2 selected
Device: LG KG275
Checking data, wait...
Action: unlock
direct unlock method #1
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
flash chip supported
sw version: ULC2GL UK OPEN KG275 P16 FL 44 V10a 234-33 AUG 17 2007 +0
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20071101-013205.B1E.bin
loading data...
data loaded
imei: 35558801049200200
Reading [eeprom-sec_35558801049200200]...
file saved: backup_eeprom-sec_35558801049200200_20071101-013206.B1E.bin
backup critical area Done
Check memory...
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
code: 77608066
Check memory Done
Write...
Erasing: eeprom-sta
Writing: eeprom-sta
Write Done
Finished, Remove/Install battery now !
Time used: 22 sec
but still insert right sim
Old 11-01-2007, 10:52   #2 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
problem solved read unlock code and enterd
all ok now
Old 11-01-2007, 22:47   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Glad to hear about good results.
If you still have this phone on hands, please, read flash and send to [email protected]
Old 03-12-2008, 22:12   #4 (permalink)
Member: 223770
Thanks Meter: 49
COM5 [VCP0] selected
Device: LG KG275
Action: unlock
Boot...
loading...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
sw version: ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1
Check parameters...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-sta_******78.B1E.bin
loading data...
data loaded
imei: 3585****9800
reading [eeprom-sec_35858*****79800]...
file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-sec_35858*******_20080312-220839.B1E.bin
reading [eeprom-complete_358582*****79800]...
file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-complete_3585****879800_20080312-220854.B1E.bin
Check memory...
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
code: 75623112
Check memory Done
Write...
Erasing: eeprom-sta
Writing: eeprom-sta
Write Done
Time used: 70 sec
bat no result phone steeeeeeeeeeeelllllllllllllllllll locked
after entring code and reseting phone no result
Old 03-12-2008, 22:40   #5 (permalink)
Member: 130995
Hello,
What you see on phone LCD when you power-on phone with wrong SIM ?
Old 03-13-2008, 09:03   #6 (permalink)
Member: 714722
Thanks Meter: 33
hi i have the same probleme iread a code but how to enter this code ?
if iinsere sim i show eroor sim
pleas ho to enter the code?
thanks for help
Old 03-13-2008, 10:30   #7 (permalink)
Member: 130995
Hello,
Sometimes it's good idea to read documentation...
C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_enter_unlock_code_LG-MG160_MG161_KG270_KG271_KG275_KG276_KG278_KG288_KG 370_KG375.txt
Infinity-Box How to enter unlock code LG-MG160 MG161 KG270 KG271 KG275 KG276 KG278 KG288 KG370 KG375
Phone is locked but does not as to enter code:
1. insert any wrong Sim-Card in phone
2. you will see on LCD: "insert correct sim"
3. type unlocking code and press Call "Green" button
4. wait for few seconds - phone will restart and unlocked
Old 03-13-2008, 13:54   #8 (permalink)
Member: 223770
Thanks Meter: 49
Originally Posted by InfinitySupport View Post
Hello,
phone steeeeeeeeel locked "insert correct sim" and after reseting with 2945#*# and entring the code and after enting code with ******#*# and send key phone steeel locked
Old 03-13-2008, 14:27   #9 (permalink)
Member: 223770
Thanks Meter: 49
Device: LG KG275
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot...
loading...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
Check parameters...
file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-sta_******66.B1E.bin
loading data...
data loaded
imei: 35858*****9800
reading [eeprom-sec_35858****9800]...
file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-sec_358582**********13-142126.B1E.bin
reading [eeprom-complete_358******9800]...
file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-complete_35858******-142139.B1E.bin
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
probably you need to restore original imei after unlock process
Write Done
Time used: 62 sec
thx br for help phone unlocked with infinity
with direct unlock method #2
Old 04-24-2008, 12:19   #10 (permalink)
v11
v11's Avatar
Member: 214827
Sonork: 100.1597158
Thanks Meter: 59
yes... method 2 work perfect.
thx. team.
kg275 UNLOCKING kaio FuriousGold 6 01-27-2008 14:34
LG KG275 unlocks needed thechachman Phone Unlocking Codes & Maps 0 12-28-2007 09:51
for kg275 unlock :) bronks FuriousGold 12 12-24-2007 03:04
KG275 unlock error ... ! llcoolr FuriousGold 5 11-06-2007 22:35
kg275 unlock .:bono:. FuriousGold 12 09-14-2007 02:35
Page generated in 0.64986 seconds with 9 queries
