04-21-2016, 07:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | Access violation error | MTK/Mediatek v1.46 Phone is an fake Lenovo S850C. With "Smart AV" i'm geting this: Code: SmartAV Init Ok! Scanning FileSystem now , please wait SmartAV Report : Removed 1 infected files! Making additional operations ... Special Op #1 : Error : Clear Error! Something went wrong! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Code: Card found : S/N : 0A5xxxxx , v0130 Chinese Miracle II [MTK module] v 1.46 Operation : Check / Read Info [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 145 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D43303447101B017DD2A1C9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x37 , OEM : 01FF [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 3701FF454D43303447101B017DD2A1C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : E25A15D5D4F951CE0F0B5FD8DF4B3928 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! SECURITY : IMEI_SW [1] : 3551312xxxxxxxx IMEI_SW [2] : 3551312xxxxxxxx BTMAC Addr : 5EDB466572E3 WiFi MAC : 00D1157D23E5 Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
04-21-2016, 07:27 | #3 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | HW test: Code: Card found : S/N : 0A5Exxxx , v0130 Chinese Miracle II [MTK module] v 1.46 Operation : HW Test [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 145 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 3701FF454D43303447101B017DD2A1C9 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x37 , OEM : 01FF [eMMC] : FLASH_INF : [NOT_IN_BASE] , G40CM [eMMC] : FLASH_CID : 3701FF454D43303447101B017DD2A1C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : E25A15D5D4F951CE0F0B5FD8DF4B3928 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3750 mV [Processing] FlashMemory Read-Write test [eMMC] : [NOT_IN_BASE] , G40CM , 0xE9000000 , 3728 MiB [eMMC] : CID : 3701FF454D43303447101B017DD2A1C9 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:38 Reconnect Power/Cable! |
04-22-2016, 07:56 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Did you tried with another piece of S898t+? Seems as firmware inside phone already damaged too much, need to full flash phone. Br. Infinity Box Support Team. |
