10-27-2016, 15:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Bulgaria Smolyan
Member: 203747 Status: Offline Thanks Meter: 94 | Acer A1-810 clean viruses problem Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.58 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 60 ] Sync... BootLoader : Not Supported! Warranty : Not Supported! Secure : Not Supported! ExtraStat : Device have SECURED sub-model! Boot Lock/Unlock NOT required for that device! for succsesful operation i need to unlock bootloader first but as you can see Boot Lock/Unlock NOT required for that device! so i CANT do it nor can do SMAR AV coz first need to read flash OR it is because BootLoader : Not Supported! Warranty : Not Supported! if so any help pls |
