10-07-2016, 15:51 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: kumasi-GHANA
Member: 1311694 Status: Offline Sonork: 100.1606976 Thanks Meter: 107 | acer a6001 frp error 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! |
10-07-2016, 16:43 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Hold volume keys and try to connect phone. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-07-2016, 17:59 | #3 (permalink) | |
Member: 1311694 Status: Offline Sonork: 100.1606976 Thanks Meter: 107 | still sir Quote:
2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 35 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x97 NAND Flash : NOT INSTALLED eMMC Flash : 90014A484147326505074F70EC3C23AF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! | |
