Acer B3-A30 FRP Reset with CM2MTK (MT8163) Hello, friends! Is it possible to remove frp of Acer B3-A30 MT8163 Tablet with Chinese Miracle 2 MTK. I tried connecting the tablet while holding different key combinations but i get two different errors: [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED and: [DA_ERROR] : DRAM Configure failed! I reckon that i should unlock the bootloader but its not possible via fastboot option :(. Any ideas? Thank you in advance!!! |
Thanks for success report :) continue like this :) |
Post complete log. Not just pieces of it. |
Sorry for that guys. Here are they: Card found : S/N : ******* , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 48 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! and the other one: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x97 NAND Flash : NOT INSTALLED eMMC Flash : 450100445332303332013191597843A3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBC000000 DRAM_INIT_REQ_FAILED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! Thank you! |
think i have found solution |
post it pls ========================= Start ========================= 21.12.2018 / 14:27:25 ================================================== ======= Card found : S/N : **********, v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [21.12.2018 / 14:28:40] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [21.12.2018 / 14:29:08] Start at : [21.12.2018 / 14:30:23] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! Finish at : [21.12.2018 / 14:30:47] Start at : [21.12.2018 / 14:32:30] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Finish at : [21.12.2018 / 14:32:55] ========================= Start ========================= 21.12.2018 / 14:37:58 ================================================== ======= Card found : S/N : FB797589 , v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [21.12.2018 / 14:38:31] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! Finish at : [21.12.2018 / 14:38:51] ========================= Start ========================= 21.12.2018 / 14:40:31 ================================================== ======= Card found : S/N : FB797589 , v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [21.12.2018 / 14:40:51] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed ========================= Start ========================= 21.12.2018 / 14:47:44 ================================================== ======= Card found : S/N : FB797589 , v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [21.12.2018 / 14:48:03] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [21.12.2018 / 14:48:14] ========================= Start ========================= 21.12.2018 / 15:01:25 ================================================== ======= Card found : S/N : FB797589 , v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [21.12.2018 / 15:02:14] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! Finish at : [21.12.2018 / 15:02:15] Start at : [21.12.2018 / 15:02:41] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Finish at : [21.12.2018 / 15:02:51] Start at : [21.12.2018 / 15:03:02] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! Finish at : [21.12.2018 / 15:03:26] |
@soulgsm you are using CM2MTK v1.58, but you can try with CM2MT2 v2.xx |
Thx Problem solved without the box but i apreciate the info verry much ! Thank you again! |
Operation : Reset Settings/Format FS [ v2.03 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM838) MODE : BOOTROM PORT : 838 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
