Old 10-12-2017, 17:07   #1 (permalink)
Member: 1429766
Thanks Meter: 57
Exclamation Acer B3-A30 FRP Reset with CM2MTK (MT8163)
Hello, friends! Is it possible to remove frp of Acer B3-A30 MT8163 Tablet with Chinese Miracle 2 MTK. I tried connecting the tablet while holding different key combinations but i get two different errors:
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
and:
[DA_ERROR] : DRAM Configure failed!
I reckon that i should unlock the bootloader but its not possible via fastboot option . Any ideas? Thank you in advance!!!
Old 10-12-2017, 19:20   #2 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 462
Thanks for success report continue like this
Old 10-13-2017, 07:51   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,662
Post complete log. Not just pieces of it.
Old 10-13-2017, 09:27   #4 (permalink)
Member: 1429766
Thanks Meter: 57
Sorry for that guys. Here are they:
Card found : S/N : ******* , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 48 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BB_CPU_NME : [MediaTek] MT8163_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Boot Error!
Operation Failed
Elapsed: 00:00:07
Reconnect Power/Cable!
and the other one:
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x97
NAND Flash : NOT INSTALLED
eMMC Flash : 450100445332303332013191597843A3
Initialize Memory ...
ErroCode : 0xBC000000
DRAM_INIT_REQ_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:08
Thank you!
The Following User Says Thank You to xukca For This Useful Post:
Old 12-04-2017, 14:21   #5 (permalink)
Member: 2627440
Thanks Meter: 5
think i have found solution
Old 12-21-2018, 14:05   #6 (permalink)
soulgsm's Avatar
Member: 1872225
Sonork: 100.1668729
Thanks Meter: 26
post it pls
========================= Start =========================
21.12.2018 / 14:27:25
Card found : S/N : **********, v0137
Start at : [21.12.2018 / 14:28:40]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Finish at : [21.12.2018 / 14:29:08]
Start at : [21.12.2018 / 14:30:23]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:23
Finish at : [21.12.2018 / 14:30:47]
Start at : [21.12.2018 / 14:32:30]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:24
Finish at : [21.12.2018 / 14:32:55]
21.12.2018 / 14:37:58
Card found : S/N : FB797589 , v0137
Start at : [21.12.2018 / 14:38:31]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Boot Error!
Operation Failed
Elapsed: 00:00:20
Finish at : [21.12.2018 / 14:38:51]
21.12.2018 / 14:40:31
Start at : [21.12.2018 / 14:40:51]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
21.12.2018 / 14:47:44
Start at : [21.12.2018 / 14:48:03]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:10
Finish at : [21.12.2018 / 14:48:14]
21.12.2018 / 15:01:25
Start at : [21.12.2018 / 15:02:14]
Wait for phone...
Phone found! [ 12 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:00
Finish at : [21.12.2018 / 15:02:15]
Start at : [21.12.2018 / 15:02:41]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:09
Finish at : [21.12.2018 / 15:02:51]
Start at : [21.12.2018 / 15:03:02]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8163
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:24
Finish at : [21.12.2018 / 15:03:26]
Old 12-22-2018, 10:43   #7 (permalink)
Member: 1043909
Thanks Meter: 51,502
@soulgsm
you are using CM2MTK v1.58, but you can try with CM2MT2 v2.xx
Old 12-22-2018, 10:45   #8 (permalink)
soulgsm's Avatar
Member: 1872225
Sonork: 100.1668729
Thanks Meter: 26
Thx
Problem solved without the box but i apreciate the info verry much ! Thank you again!
Old 01-13-2019, 20:39   #9 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 386
Originally Posted by YellowBoss View Post
@soulgsm
I also need to remove FRP on this tablet based on MT8163 Surftab Theatre L15 - TREKSTOR - DEINE TECHNIK
Operation : Reset Settings/Format FS [ v2.03 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM838)
MODE : BOOTROM
PORT : 838
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Page generated in 0.36128 seconds with 7 queries
