09-18-2018, 13:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: boghé-mauritania Age: 48
Member: 106412 Status: Offline Thanks Meter: 15 | Acer iconia one 10 b3-a40 fhd model:a7002 itry connect this tablet and get this error, and i do what the soft ask,but always same problem 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital Boot Ok! BB_CPU_PID : 8167 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0001 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
10-21-2018, 20:22 | #4 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | scatter file: ################################################## ################################################## ######## # # General Setting # ################################################## ################################################## ######## - general: MTK_PLATFORM_CFG info: - config_version: V1.1.2 platform: MT8167 project: neostra8167_tb_n storage: EMMC boot_channel: MSDC_0 block_size: 0x20000 ################################################## ################################################## ######## # # Layout Setting # ################################################## ################################################## ######## - partition_index: SYS0 partition_name: preloader file_name: preloader_neostra8167_tb_n.bin is_download: true type: SV5_BL_BIN linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0x40000 region: EMMC_BOOT_1 storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BOOTLOADERS is_upgradable: true reserve: 0x00 - partition_index: SYS1 partition_name: pgpt file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x0 physical_start_addr: 0x0 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS2 partition_name: proinfo file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x80000 physical_start_addr: 0x80000 partition_size: 0x300000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS3 partition_name: nvram file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x380000 physical_start_addr: 0x380000 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: BINREGION is_upgradable: false reserve: 0x00 - partition_index: SYS4 partition_name: protect1 file_name: NONE is_download: false type: EXT4_IMG linear_start_addr: 0x880000 physical_start_addr: 0x880000 partition_size: 0xa00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS5 partition_name: protect2 file_name: NONE is_download: false type: EXT4_IMG linear_start_addr: 0x1280000 physical_start_addr: 0x1280000 partition_size: 0xa00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS6 partition_name: persist file_name: NONE is_download: false type: EXT4_IMG linear_start_addr: 0x1c80000 physical_start_addr: 0x1c80000 partition_size: 0x3000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS7 partition_name: seccfg file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x4c80000 physical_start_addr: 0x4c80000 partition_size: 0x40000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS8 partition_name: lk file_name: lk.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x4cc0000 physical_start_addr: 0x4cc0000 partition_size: 0x60000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS9 partition_name: lk2 file_name: lk.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x4d20000 physical_start_addr: 0x4d20000 partition_size: 0x60000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS10 partition_name: boot file_name: boot.img is_download: true type: NORMAL_ROM linear_start_addr: 0x4d80000 physical_start_addr: 0x4d80000 partition_size: 0x1000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS11 partition_name: recovery file_name: recovery.img is_download: true type: NORMAL_ROM linear_start_addr: 0x5d80000 physical_start_addr: 0x5d80000 partition_size: 0x1000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS12 partition_name: para file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x6d80000 physical_start_addr: 0x6d80000 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS13 partition_name: logo file_name: logo.bin is_download: true type: NORMAL_ROM linear_start_addr: 0x6e00000 physical_start_addr: 0x6e00000 partition_size: 0x800000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: false reserve: 0x00 - partition_index: SYS14 partition_name: expdb file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x7600000 physical_start_addr: 0x7600000 partition_size: 0xa00000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS15 partition_name: frp file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x8000000 physical_start_addr: 0x8000000 partition_size: 0x100000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS16 partition_name: tee1 file_name: tz.img is_download: true type: NORMAL_ROM linear_start_addr: 0x8100000 physical_start_addr: 0x8100000 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS17 partition_name: tee2 file_name: tz.img is_download: true type: NORMAL_ROM linear_start_addr: 0x8600000 physical_start_addr: 0x8600000 partition_size: 0x500000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS18 partition_name: kb file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x8b00000 physical_start_addr: 0x8b00000 partition_size: 0x200000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS19 partition_name: dkb file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x8d00000 physical_start_addr: 0x8d00000 partition_size: 0x200000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: PROTECTED is_upgradable: false reserve: 0x00 - partition_index: SYS20 partition_name: metadata file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0x8f00000 physical_start_addr: 0x8f00000 partition_size: 0x2100000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: INVISIBLE is_upgradable: false reserve: 0x00 - partition_index: SYS21 partition_name: system file_name: system.img is_download: true type: EXT4_IMG linear_start_addr: 0xb000000 physical_start_addr: 0xb000000 partition_size: 0xed000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: true reserve: 0x00 - partition_index: SYS22 partition_name: cache file_name: cache.img is_download: true type: EXT4_IMG linear_start_addr: 0xf8000000 physical_start_addr: 0xf8000000 partition_size: 0x20000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: false reserve: 0x00 - partition_index: SYS23 partition_name: userdata file_name: userdata.img is_download: true type: EXT4_IMG linear_start_addr: 0x118000000 physical_start_addr: 0x118000000 partition_size: 0xc0000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: true is_reserved: false operation_type: UPDATE is_upgradable: false reserve: 0x00 - partition_index: SYS24 partition_name: flashinfo file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0xFFFF0084 physical_start_addr: 0xFFFF0084 partition_size: 0x1000000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: false is_reserved: true operation_type: RESERVED is_upgradable: false reserve: 0x00 - partition_index: SYS25 partition_name: sgpt file_name: NONE is_download: false type: NORMAL_ROM linear_start_addr: 0xFFFF0004 physical_start_addr: 0xFFFF0004 partition_size: 0x80000 region: EMMC_USER storage: HW_STORAGE_EMMC boundary_check: false is_reserved: true operation_type: RESERVED is_upgradable: false reserve: 0x00 |
