Acer Lconia B1-A71 Secure Boot Not Supported Acer Lconia B1-A71 Secure Boot Not Supported Quote:
1 Attachment(s) Quote:
may be some incompatibility with newer loaders ... Use attached DA_Agent, change existing DA_Agent in CM2MTK folder, try to boot device. More info on DA change - HERE Since you didn't wrote what you want to do ... cant help more. In case you need ROM file ... download here : b1-a71_1.174.00.ww.gen1 or here : https://mega.nz/#F!34QQ1Y6C!cE0Q-VsD...8lRYA!G4ByxbrR in case you need SPFlashTool... https://mega.nz/#F!34QQ1Y6C!cE0Q-VsD...8lRYA!69glAaLC b.r. Alex |
Small add-on ... in case you cant write flash, download SPFT with "security disable" file, to be written with SPFlashTool "write memory" option. Check instructions inside archive, and correct address for writing on pictures. BE CAREFULL, not to make mistake. You can kill the device. b.r. Alex |
Same problem, with DA_Agent from link not work DA_Agent from here damaged Code: Operation : Read Flash [ v1.58 ] |
