Old 09-30-2017, 13:49   #1 (permalink)
::SYED MOBILE::'s Avatar
Member: 1427732
Sonork: ˙٠●
Thanks Meter: 1,050
Unhappy Acer Lconia B1-A71 Secure Boot Not Supported
Card found : S/N : XXXXXX , v0136
Start at : [9/30/2017 / 4:06:17 PM]
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:05
Reconnect Power/Cable!
Finish at : [9/30/2017 / 4:06:22 PM]
Old 10-01-2017, 00:32   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,447
Originally Posted by ::SYED MOBILE:: View Post
Acer Iconia B1-A71 Secure Boot Not Supported
It's not secure boot, but older boot, older cpu,
may be some incompatibility with newer loaders ...
Use attached DA_Agent, change existing DA_Agent in CM2MTK folder,
try to boot device.
More info on DA change - HERE
Since you didn't wrote what you want to do ... cant help more.
In case you need ROM file ... download here : b1-a71_1.174.00.ww.gen1
or here : https://mega.nz/#F!34QQ1Y6C!cE0Q-VsD...8lRYA!G4ByxbrR
in case you need SPFlashTool...
https://mega.nz/#F!34QQ1Y6C!cE0Q-VsD...8lRYA!69glAaLC
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 10-01-2017, 00:49   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,447
Small add-on ... in case you cant write flash,
download SPFT with "security disable" file, to be written with
SPFlashTool "write memory" option.
Check instructions inside archive, and correct address for writing on pictures.
BE CAREFULL, not to make mistake. You can kill the device.
b.r.
Alex
__________________
Old 10-18-2017, 14:04   #4 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 142
Same problem, with DA_Agent from link not work
DA_Agent from here damaged
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 0300771F
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 0300771F
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Boot Error!
Operation Failed
Elapsed: 00:00:06
Page generated in 0.20802 seconds with 8 queries
