06-03-2015, 03:07 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: inside the box Age: 40
Member: 765233 Status: Offline Sonork: 100.1664273 Thanks Meter: 107 | acer liquid z200 tool DL image fail and tool DL image fail upper on screen Operation : Reset Privacy Lock [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758EBF2A1AE913B DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758EBF2A1AE913B [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Privacy Lock reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
06-03-2015, 04:01 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | may be this can help u . http://mon-nuage.net/Z200/Z200+TOOL+AND+IMAGE.zip |
06-03-2015, 07:14 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It is really hard press "Fix DL" button in service tab? As see in log - "Safe Mode" used - that mean Data inside is need - so flashing not usable at all. Fix DL. |
06-03-2015, 07:50 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
06-03-2015, 09:43 | #6 (permalink) |
Member: 765233 Status: Offline Sonork: 100.1664273 Thanks Meter: 107 | the phone works fine now i do like this 1 reset privacy after this the phone always restart the screen upper tool DL image fail 2 flash the phone using flashtool now the phone turn on and they have pattern lock 3 reformat the phone by hard reset done |
06-03-2015, 10:55 | #8 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
If Easy Way Available, So Still We Have To Use Long Way ?. I Hope Next Time This Post Will Help You. http://forum.gsmhosting.com/vbb/f296...e-cm2-1933796/ | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
