05-03-2018, 17:04 | #1 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Acer tab 10: B3-a20 (a5008). Acer iconia one 10 B3-A20 model : A5008 supported in New and latest setup Mtk2.0r2. But i have problem can not connect. Operation : Identify [ v2.00 r2 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM58) MODE : BOOTROM PORT : 58 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT8163 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! It says LEGACY but when i copy DA and rename in 1.58 but over their still same says that its secureboot still. Card found : S/N : 3EA4381E , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 8163 BB_CPU_NME : [MediaTek] MT8163_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Please need help. Thanks Br, Raja |
05-05-2018, 08:03 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Seems you need correct DA for this model. Can also try with volume keys pressed and check result. Br. Infinity Box team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-05-2018, 17:51 | #6 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
https://t.me/kamal_singla Wht mean bro ? | |
