09-20-2010, 05:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Dapeng t2000 very strange problem after formate the phone PLACE PHONE ON LEVEL SURFACE THEN PRESS LSK TO START ACCELEROMETER CALIBRATION. WHAT TO DO HERE IS MY LOG Code: Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E710_HJY2QWN18.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E710_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E710_HJY2QWN18_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E710_HJY2QWN18.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: [standard] type (05) TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 1 min 30 sec Remove/Install battery now ! BEFOR IT HAS USER LOCK BUT I CAN GO TO MENU |
09-20-2010, 06:09 | #2 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Ans when i m trying to fix calibrate always saying this i already modified my infinity box so its should be no problem be for i had same problem with different phone when i try to fix calibrate always give me this error Quote:
09-20-2010, 22:55 | #4 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
and press lsk where should i press lsk? in the phone only showing ok button to press and i can not even press ok button and where is Accelerometer? can u plz tel me step by step plz thanks | |
09-22-2010, 00:09 | #6 (permalink) | |
plz advice me u ther mster thanks salim | |
10-16-2010, 06:37 | #7 (permalink) |
Junior Member Join Date: Sep 2010 Location: manila,philippines Age: 33
Member: 1404892 Status: Offline Thanks Meter: 0 | can anyone help me i hve problem using the wifi of the phone.. it always says connection failed do it have a certain config for the wlan? and is it possible to put a new thumbnail in the main menu of the cp???? |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
