01-15-2017, 11:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Republic Of South Africa Age: 27
Member: 2562560 Status: Offline Thanks Meter: 56 | Attention Please About MT6261 Firmware Read Error ;( Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 5032A31A45BADB73C2B782D9DB8B0EF9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : SX9_PCB01_gprs_MT2502_S00.GM18S_TONE_128_T1_L2_C4_G10_A.bin FileVersion : GM18S_TONE_128_T1_L2_C4_G10_A Code : 0x00, error while making FW! Make FlashRead as dump and send to support! Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
