Old 06-01-2015, 07:16   #1 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
lava iris 350m cant read paatern code
Operation : Read PatternLock [ v1.21 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001500010000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0087 , UNKNOWN
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
Reading data ...  Please, wait
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:28
Reconnect Power/Cable!
Old 06-01-2015, 07:29   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Pattern is set? If yes - readout dump and send me for check.
Old 06-01-2015, 07:33   #3 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:28
PatternLock not set
May Be Any Third Party Application ?
or may be there is gmail not pattern?
Old 06-01-2015, 09:24   #4 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
no there is no third party application and i know its pattern dump uploaded soon wait
Old 06-01-2015, 14:22   #5 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
here is links of dump
firmware is rooted because pattern code readed by other tool
part 1
part 2
part 3
pattern code-157842
logs
Operation : Read Flash [ v1.21 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Read Ok , collect info
MTKxCPU   : MT6572
MTKxPRJ   : wt97057
Saved to : L:\MT6572__wt97057.ispff
Done!
Elapsed: 00:03:23
Old 06-01-2015, 14:25   #6 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
karbon a90 not read pattern code
dump is upload soon
Operation : Check / Read Info [ v1.21 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
EXT RAM    : 0x10000000
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done [33]
[AP] : Initial info read Ok!
Done!
Elapsed: 00:01:02
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:19
Old 06-01-2015, 14:29   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks. It is my fault - will add that flash ic ( and same with such params as well ) in next update.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Old 06-02-2015, 19:48   #8 (permalink)
JayDi's Avatar
Member: 462970
@rehmani , repack archive and reupload. It damaged.
Old 06-03-2015, 06:49   #9 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
here is karbon a90 links .lava iris 350m firmware is uploading soon
1st part
2nd part
3rd part
4th part
pattern code is 1258
Old 06-03-2015, 10:18   #10 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
here is link of lava iris 350m dump get it
Old 06-03-2015, 10:44   #11 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
dump is upload soon
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:01:02
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Checking ...
PatternLock not set
Done!
Elapsed: 00:01:19
Dear Friend,
Karbonn A90 Has Spreadtrum CPU ID SC6820
Karbonn A90s MediaTek MT6572 eMMC. Not NAND.
Karbonn A90s Factory Firmware Writing Test Report.
Karbonn A90s IMEI Repaired By Infinity CM2.
So Please Correct Model.
Old 06-03-2015, 11:32   #12 (permalink)
Member: 459784
Thanks Meter: 1,543
Originally Posted by mygsm world View Post
Dear Friend,
Model Should Be A90s He Forgot To mention Only "S"
Old 06-03-2015, 11:50   #13 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
Dear Friend,
yes you are right sorry bro model is a91 h\w-a3672_4mb_p1 s\w-karbon_a91_v1.0
and correct pattrn-6547
Page generated in 0.23325 seconds with 9 queries
