05-17-2017, 09:35 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Pakistan
Member: 1000101 Status: Offline Thanks Meter: 13 | huawei y5ii dead after try frp reset? with log . any soultion plz.need factory file 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303038473730001954A2F973A5 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
05-17-2017, 10:05 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
05-17-2017, 13:51 | #3 (permalink) |
Member: 1000101 Status: Offline Thanks Meter: 13 | [QUOTE=Kirumira;12503382]No operation done to your phone,check your battery and SELECT "FRP PROTECTION"[/Q battery fully charge but phone not power on . only take 7 amp on supply. bro you have factory file>? |
05-18-2017, 08:36 | #7 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | repair files https://yadi.sk/d/gBnzuLGN3G7M6Y and here another file: https://yadi.sk/d/SOrS24ic3GC5eR choose Download-Agent DA_SWSEC.bin from 807_sec_da folder. thx goes to 4pda.ru |
The Following 3 Users Say Thank You to BouRRi_GSM For This Useful Post: |
05-20-2017, 12:40 | #8 (permalink) | |
Member: 1000101 Status: Offline Thanks Meter: 13 | Quote:
The Following User Says Thank You to aqeelrovi For This Useful Post: |
05-23-2017, 13:07 | #9 (permalink) | |
Member: 1000101 Status: Offline Thanks Meter: 13 | inferano suported huawei y5ii mt 6582?? factory file no write this? Quote:
05-24-2017, 06:05 | #10 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | This is part 2 https://yadi.sk/d/JYhmrVgr3GCTV5 And use SP_Flash_Tool_exe_Windows_v5.1548.00.000-secure choose Download-Agent DA_SWSEC.bin from 807_sec_da folder. Those file are from 4pda.ru |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
05-24-2017, 07:00 | #11 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | init preloader hope this will save you from full flashing and further issues. Y5II (CUN-U29) Preloader Quote:
05-24-2017, 11:03 | #12 (permalink) | |
Member: 1000101 Status: Offline Thanks Meter: 13 | huawei y5ii frp lock which device remove? Quote:
