11-17-2017, 13:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | Gionee F103 Network issue, Not done Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5332380B360042619A6BDE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS28 [eMMC] : FLASH_CID : 150100513832534D4200360BDE6B7261 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0CE0470BDFE0F3F433FD3B6DB7857EE3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 868510021336572 IMEI [01] : 868510021336572 Set IMEI [00] : 356645398704231 Set IMEI [01] : 356436498707781 Prepare finished. Security check required! Wait for phone... Phone found! [ 15 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! cc; jaydi |
11-18-2017, 03:57 | #3 (permalink) |
Member: 2592600 Status: Offline Thanks Meter: 19 | |
11-18-2017, 06:37 | #4 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | here a tip erase all flash them write a good FW and nvram from working device too and repair BB and post here result if not work its Hardware problem i have one with imei null and haved tryed all tips but nothing work for me still null |
11-18-2017, 09:24 | #5 (permalink) | |
Member: 2592600 Status: Offline Thanks Meter: 19 | Quote:
Sent from my C1001 using Tapatalk | |
01-21-2018, 14:59 | #9 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Full Erase and then flash with latest version, that's enough to bring Baseband to alive state. You can also try Repair Baseband -Fix Unknown Baseband (With/without BB deep fix) option in CM2MTK module. After write NVRAM (if required) and repair security. Tested NVRAM attached. Br. Infinity Box Team. | |
