01-10-2010, 07:55 | #1 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 36
Member: 1116719 Status: Offline Thanks Meter: 542 | after falsh nokia 6300 dead... module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware CM_Nokia-6300_SKYWORTH25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_20_MP_V12_16m_Ru_Fr_En_Malaysia_Indonesia_Th_ Vn_Cn_Hi_Ar_Cn_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001503:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 01227E22202200:18A59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100109-221745.B0E.bin flash: 01227E22202200:18A59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22202200:18A59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 31 min 59 sec Remove/Install battery now ! waht.problem ? sir plz solving this . |
nokia 6300 dead after flahing plz help me | nishatmohd | Nokia Hardware & Hardware Repair | 9 | 02-06-2009 19:22 |
Nokia 6300 dead after Bb5box? | xmans | Nokia Hardware & Hardware Repair | 3 | 09-24-2008 05:10 |
falsh nokia 6300 pb | fateh76dz | HWK | 1 | 01-30-2008 21:18 |
Nokia 6300 Dead after formating | Ramzan | Infinity-Box | 4 | 10-01-2007 17:21 |
nokia 6300 dead after flashing | HIM | Universalbox | 3 | 07-13-2007 21:51 |
