07-02-2008, 17:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | after ffs format it shows (bad softwere) chk info COM3 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:A203:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN ver. sw2: M608_V_1.11_P1HxM25BC30_CN, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. .... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 69 sec Remove/Install battery now ! |
07-02-2008, 18:31 | #3 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | Sir i try this but still same (BAD SOFTWERE) here is log COM3 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:A203:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN ver. sw2: M608_V_1.11_P1HxM25BC30_CN, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN]]... file saved: G:\Program Files\InfinityBox\ChineseMiracle\eeprom[MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN]_20080702-225244.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 601 sec Remove/Install battery now ! |
07-02-2008, 19:40 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Quote:
frimwer : MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN eeprom; MOBILEDEN25_06B_PCB01_GPRS_MT6225_ and flash workinh 100% ok br.dynet | |
07-02-2008, 21:33 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. We strongly suggest you to make flash backup for emergency case !!! 2. Infinity-Box programmers working now about "one-big-repair-button" solution for "wrong software" |
07-04-2008, 18:44 | #6 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | Thanks for sugestion sir i already make flesh backup, from spuort can i use any file for fleshing becoz on suportsite firmwere and eeproom r same and many files with this name (frimwer : MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_11_ P1HXM25BC30_CN.BIN eeprom; MOBILEDEN25_06B_PCB01_GPRS_MT6225_) what should i do and from last two days when i try to download files from suport it give me some error ( service temprory unavaiable) if download start after 10 to 15% it again stop with some other error (no virus problem becoz from jaf and hwk suport i m downloading files regularly) |
07-04-2008, 19:07 | #7 (permalink) |
Freak Poster Join Date: Oct 2004 Location: India
Member: 86448 Status: Offline Sonork: 100.113881 Thanks Meter: 106 | Realy we need it, If we take backup it is taking long time, so maximum time we people ignoring it. Also fade up with bad software problem in pda ( Chinese ) Phones. |
Siroya please hellpme f275l dead after ffs format | soulcelulares | UST Pro II | 2 | 07-16-2009 16:31 |
After Ffs Format-only One Sim Work-why? | zonetrichur | Infinity-Box | 19 | 04-07-2009 16:25 |
Nokia N70 After Ffs Format No Network | Mansoor | Infinity-Box | 3 | 06-11-2008 21:51 |
N95 after FFS formatting also with SIM gets OFF.. | harim_1981 | Infinity-Box | 3 | 09-20-2007 05:05 |
Gm 259 After Ffs Format Dead | jothi737 | Infinity-Box | 3 | 08-27-2007 10:20 |
