Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: (03434940123)PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 759 ![]() | After flash 6300 not powerup LOG ARE COM5 [VCP0] selected module v2.96 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 _16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __ffs_01.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:A3B0:B316 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: 3AEFE431 rom info protocol ver: 04 ver. sw 1: A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 .BIN ver. sw 2: A909B_YY01_00_1.0T06_0711, C87562E3 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\A8_PCB01_GPRS_MT6 226_S01.A909B_YY01_00_1_0T06_0711__ffs_20091103-172814.B0E.bin flash: EC257E25082501:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent I THINK THIS ERROR file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711_ _system_log_3AEFE431_E36275C8_20091103-173012.B0X.bin Area: Firmware flash: EC257E25082501:2BEA0000000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:2BEA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711_ _system_log_3AEFE431_E36275C8_20091103-173042.B0X.bin Finished, time used: 522 sec Remove/Install battery now ! PLEASE HELP ME |
![]() | #7 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 759 ![]() | i get two flashes on support mt 6226. i try both but problem not solved. i try to used format ffs but set not goes to test mode. this hand set NOHA AND back model 6300 type rm-166. made in finland this hand set histrory it is ok i formate rong and my mistake not read full flash.Now support area two flashes i try two but sam i know this is software fualt. INFNITY HELP TOLD we have 3 flash files with this version.BUT i got two please help |
![]() | #9 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks Meter: 15,057 | hello! find out which you miss and try it flashfiles/ChineseMiracle/_MT6226/A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 _16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __Nokia-6300-RM-217_16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6205-MT6227/other3/6300_BLUETOOLTH_A8_PCB01_GPRS_MT6226_S01.A909B_YY0 1_00_1_0T06_0711_16m_En_Ru_Fr_De_Malaysia_Th_Vn_Cn _Ar_w_eep.B0M.bin |
6300 after flashing charger not supported | SE4U | Nokia Base Band 5 ( BB-5 ) | 3 | 04-13-2012 15:53 |
I Got a Problem after Flashing 6300 Meiye Q7 | torpedo_seluler | Infinity-Box | 13 | 11-04-2010 11:37 |
It is posible that after flash 6300 phone locked? | stylius | MT-BOX | 4 | 10-02-2007 17:33 |
