03-16-2019, 09:06 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | After flash logo A37f oppo OPPO A37f after flash it is on logo check here Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20959AB8 ID_BLOCK_L : CD37ADA904929F8A752A2A2BF44FC707 ID_BLOCK_L : 4C07892015BC2EA75A95FE373DF0EEED Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 Manufact. : OPPO SysPatch : LMY47V DevComTime: 08-Oct-17 9:26:49 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:21 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 CU_SWVer : OPPO Device Compile : 10/8/2017 9:26:49 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20959AB8 ID_BLOCK_L : CD37ADA904929F8A752A2A2BF44FC707 ID_BLOCK_L : 4C07892015BC2EA75A95FE373DF0EEED Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:10:53 Phone is on.I flash this because when I call it say disable the airplane mode but it is not in airplane mode. So I try to flash the same version but now it is on logo how to recover this bro Tx |
03-17-2019, 14:54 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, First check emmc state for Read Only. Next try with latest firmware version. Br. Infinity-Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-18-2019, 08:29 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | HELLO @sky_finder YOUR PHONE IS A37FW FLASH YOUR PHONE WITH A37FW AND YOUR PROBLEM WILL SLOVE POST RESULT GOOD LUCK! |
The Following User Says Thank You to gracy_elec For This Useful Post: |
03-18-2019, 16:06 | #7 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: cameroon
Member: 1356561 Status: Offline Thanks Meter: 433 | Quote:
https://drive.google.com/uc?export=d...UZJb1pCS0s4TGM https://www.youtube.com/watch?v=2r5nLTPVzcA | |
The Following User Says Thank You to idrissou mohama For This Useful Post: |
03-19-2019, 06:22 | #8 (permalink) | |
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote: Too many users have viewed or downloaded this file recently. Please try accessing the file again later. If the file you are trying to access is particularly large or is shared with many people, it may take up to 24 hours to be able to view or download the file. If you still can't access a file after 24 hours, contact your domain administrator. | |
