12-25-2010, 11:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | after flash phone is in white display i need help i have this phone is hang condition i format this phone but still same then i download this file from server & flash it. after flash phone is in white display now plz tell me what i do flashing log Code: ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7F41:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: FF008803001021:90008800000000 flash: FF008803001021:90008800000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: DAYO23C_08A_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_28_MP_V1_F4.BIN project-id: MAUI.08A.W08.28.MP.V1.F4, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 25 sec Remove/Install battery now ! Code: COM3 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7F41:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: FFFFFFFFFF7FFF:90FFFF00000000 flash: FFFFFFFFFF7FFF:90FFFF00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: FFFFFFFFFF7FFF:90FFFF00000000 flash: FFFFFFFFFF7FFF:90FFFF00000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: DAYO23C_08A_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_28_MP_V1_F4.BIN project-id: MAUI.08A.W08.28.MP.V1.F4, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 53 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-27-2010, 19:26 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! did you try both files available on support? flashfiles/ChineseMiracle/Anycool/DAYO23C_08A_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08A_W0 8_28_MP_V1_F4__Anycool-D528_16m_En_El_Fr_Es_It_De_Pt_Bg_Cz_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6223/DAYO23C_08A_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08A_W0 8_28_MP_V1_F4__Anycool-D528_16m_En_El_Fr_Es_It_De_Pt_Bg_Cz_Ar.B0M.bin |
12-28-2010, 06:45 | #6 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
MT6223/DAYO23C_08A_PMWY_PCB01_GPRS_MT6223_S00.MAUI_08A_W0 8_28_MP_V1_F4__Anycool-D528_16m_En_El_Fr_Es_It_De_Pt_Bg_Cz_Ar.B0M.bin no i have not backup | |
12-28-2010, 07:32 | #7 (permalink) | |
