04-14-2006, 17:37 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 47
Member: 158620 Status: Offline Thanks Meter: 4 | After flash VK900 Problem @Support I flash the CN file download from support area, after flash power on phone, just show "VK logo" and then power off, please help and before i send you Hongkong version backup flash file, can you make is for firmware and FFS file ? thanks Regards, PGTL |
04-15-2006, 16:17 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | vk900 try every flash from ur support but none works, vk900 dead after flash. It still accepts flashing. please put good flash in support, thank you. ---------------- Log opened: [13.04.2006] [21:39:14] App: E:\Programme\InfinityBox\VkMob01\VkMob01.exe [Infinity Box] v.1.11A Loading, wait... S/N: 0xxx:0xxx Wait... Current device: VK207i Done Current device: VK900 Loading file [version 01]... VK900Z20_HZ3.20R_Th.26M.bin Loaded COM3 selected Device: VK900 Checking data, wait... Action: Flash write Write: Firmware Skip: FFS/File system Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0001:227E try to recovery erase error [3F] try to recovery erase error [3F] Err: no any answer Writing Fail Finished Remove/Install battery now ! Time used: 28 sec COM3 ready Loading file [version 01]... VK900Z20_HZ3.20R_Th.26M.bin Loaded COM3 selected Device: VK900 Checking data, wait... Action: Flash write Write: Firmware Skip: FFS/File system Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0001:227E Flash: 0001:227E Writing Done Finished Remove/Install battery now ! Time used: 1107 sec COM3 ready COM3 selected Device: VK900 Checking data, wait... Action: Flash write Write: Firmware Skip: FFS/File system Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware Flash: 0001:227E Flash: 0001:227E Writing Done Finished Remove/Install battery now ! Time used: 162 sec Loading file [version 01]... VK900Z20_HZ3.20R_Th.26M.bin Loaded Last edited by mrfixit; 04-15-2006 at 17:40. |
04-15-2006, 17:03 | #4 (permalink) | |
After flashing try to press and hold phone power button for some time (it's need some time for file system rebuilding). | |
04-15-2006, 17:34 | #5 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | phone had key lock, tried to unlock this, after unlock blank, tried to flash, after flash "update filesystem" restarting, but not more than that. any advice? thanks |
04-15-2006, 18:07 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | "phone dead" <> "restarting" as I can understand: after flashing phone tied to power on but can't power on. Instead of normal power-on process you see on phone LCD text "update filesystem" and phone restart. Is it complete problem description or you can add something ? Do you see the same restarting problem after flashing different flash files ? |
04-15-2006, 18:18 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If my description of problem was correct, try to make this: Downlaod from support area just uploaded files: Repair File System VK900_FFS_01.26F.bin (145 KB) VK900_FFS_02.26F.bin (72 KB) VK900_FFS_03.26F.bin (107 KB) VK900_FFS_04.26F.bin (97 KB) Flash it one by one (only file system files, no need to flash firmware every time) and see results. |
04-16-2006, 22:55 | #8 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I tried all of the ffs files, still no good, vk900 try to start up but keeps blinking from gray to black, flashing still works, any more ideas? maybe put another flash in support, thank you. VK900Z20_HZ3.20R_Th.26M.bin file is the only one where I get a brief logo at start up and then "update filesystem" and phone restarting. it has a date label at the back 31/03/06 covering a screw. it was working before I connect to infinity trying to unlock key lock. please help. |
04-16-2006, 23:27 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Flash phone with VK900Z20_HZ3.20R_Th, try to power on, let phone try to start and make several restart cycles. Remove battery, put back, read flash and send to [email protected] (pls, include full text from back phone label, imei too). What languages was in phone ? Other flash files: all files that we have already uploaded in support area. |
04-18-2006, 00:08 | #10 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | I read flash, Backup_full_part_1_of_2_2006-4-17_17-55-37.26X.bin 3.8mb and Backup_full_part_2_of_2_2006-4-17_18-8-44.26X.bin 2.9mb big, are they from new vk900 hardware? your files in support, are way different size: main flash about 13.5mb and fss file only about 100 kb. I sent you the back up with info to your posted email. |
04-18-2006, 00:12 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | File size is different because it's internally packed: http://forum.gsmhosting.com/vbb/showthread.php?t=287829 |
04-18-2006, 19:11 | #13 (permalink) | |
http://forum.gsmhosting.com/vbb/show...81&postcount=6 http://forum.gsmhosting.com/vbb/show...81&postcount=7 http://forum.gsmhosting.com/vbb/show...73&postcount=7 so now I am looking for readed flash from latest VK900. also, pls, give me text from your phone back label. | |
