01-27-2016, 05:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1792561 Status: Offline Thanks Meter: 78 | After format lenovo A319 dead need help please it was hang on lenovo logo i format it format sucess but set dead. Code: Card found : S/N : 0xxxxxxx , v0130 Chinese Miracle II [MTK module] v 1.40 Start at : [1/26/2016 / 4:13:31 PM] Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 75 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48344732611101FCF4B91E52A5 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101FCF4B91E52A5 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Finish at : [1/26/2016 / 4:13:50 PM] After show this Code: Start at : [1/26/2016 / 4:14:01 PM] Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 85 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A48344732611101FCF4B91E52A5 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! Finish at : [1/26/2016 / 4:15:35 PM] i try flash official fw [Lenovo_A319_ROW_DS_S308_150115] but get error need help Last edited by ajmal786; 01-27-2016 at 05:39. Reason: add red tag |
01-27-2016, 05:54 | #2 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | hello @ ajmal786 your preloader dead after format... you need to flash with same preloader firmware... try this another version Lenovo A319 One by one... Your Problem Will be sloved |
01-27-2016, 05:59 | #3 (permalink) |
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | Try This one by One Below link Lenovo_A319_S305_141125.zip Lenovo_A319_S234_141018.zip Lenovo_A319_S232_140926.zip |
The Following User Says Thank You to the boss atik For This Useful Post: |
05-27-2017, 00:24 | #4 (permalink) | |
Insane Poster Join Date: Nov 2015
Member: 2485783 Status: Offline Thanks Meter: 8 | Quote:
Sent from my Nexus 6 using Tapatalk | |
05-30-2017, 06:24 | #7 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | When Format any Mediateck Devices, Always Read Flash First. Bcoz afert Format when Devices is Dead, then just write Readed flash file. After write 100% your Devices is come 1st condition... |
05-30-2017, 06:43 | #8 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Ilam,Nepal
Member: 2378764 Status: Offline Sonork: I Dont Use !!! Thanks Meter: 60 | Dont Worry , Just Flash With Lenovo Officail Firmware A319 And Choose FORMAT+ALL (death conditon only ) , Your Mobile Will Alive and working Well !!! |
