Old 04-14-2010, 16:12   #1 (permalink)
Member: 742476
Thanks Meter: 25
after format no work lcd
chines phone
E553_Z16ARTVC_E553_GPRS_MT6226_S01.01_1.BIN
after format phone is work but lcd not work
Old 04-14-2010, 16:15   #2 (permalink)
Member: 742476
Thanks Meter: 25
COM18 [VCP6] selected
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:A9DF:324B
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.691F42B1.[E553_Z16ARTVC_E553_GPRS_MT6226_S01.01_1.BIN_1D2375 27].rpl
rom info detection finished
device-id: 691F42B1
rom info ver: 04
sw version: E553_Z16ARTVC_E553_GPRS_MT6226_S01.01_1.BIN
project-id: E553_Z16ARTVC.01.1, 2775231D
code offset: 00000000
ffs offset/size [01]: 00800000/001FF000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00800000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 553_Z16ARTVC_E553_GPRS_MT6226_S01.01_1__system_log _691F42B1_1D237527_20100414-184433.B0X.bin
Finished, time used: 1 min 27 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-14-2010, 21:29   #3 (permalink)
Member: 148515
Thanks Meter: 15,047
hello!
flash phone with some similar flash file from support:
E553_xxxxxxxxxxx_E553_GPRS_MT6226_S01.01_1.BIN
by "xxxxxxxxxxx" i mean any data
Old 04-17-2010, 09:30   #4 (permalink)
Member: 742476
Thanks Meter: 25
thanks for instruction me
download file by support and write in phone and phone is work now
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 09:03
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 16:48
wintesla doesnt work ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:51
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Page generated in 0.25179 seconds with 8 queries
