Old 03-09-2009, 19:26   #1 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
after formate this phone now is dead
COM1 selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:85E6:3406
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.088E81D3.[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN_0570D15 5].rpl
identification#1 detection finished
device-id: 088E81D3
identification#1 protocol ver: 04
ver. sw1: E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E558_ZK2ARTF.01.1, AA2E8FFA
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00800000
ffs chip: 00
eeprom/ffs area: 00000000:00800000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN]...
warning: wrong data size at 0x00A23800, retry...
read error recovered
warning: wrong cs at 0x00B62800, retry...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\eeprom[E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1.BIN]_20090309-155101.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Fail
file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_088E81D3_E558_ZK2ARTF_E558_GPRS_MT6226_S 01.01_1.BIN_0570D155_20090309-155112.B0X.bin
Finished, time used: 411 sec
Remove/Install battery now !
Old 03-09-2009, 19:30   #2 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
other log of ded phone
COM1 selected
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
Initialize Done
Set baud...
115200
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00E00000
Do you want to use standard ffs address: 00E00000 ?
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Write...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
Finalization Done
Finished, time used: 79 sec
Old 03-09-2009, 22:01   #3 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
Originally Posted by charletan View Post
COM1 selected
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
device-id: 088E81D3
ffs chip: 00
Write...
Write Done
Finalization...
formatting...
Finalization Fail
Do you have original full flash backup ?
Old 03-10-2009, 09:42   #4 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
yes i have only originale eprom backup
Old 03-10-2009, 12:40   #5 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
we have E558_ZK2ARTF_E558_GPRS_MT6226_S01.01_1 firmwareS on support.
download and flash to your phone
Old 03-10-2009, 18:52   #6 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
hello!
thanks infinity help
problem solved
after unlock my w180 now is dead hans salim Rocker Dongle (By Legija) 2 09-05-2008 15:41
dead after format this phone.. alf007 VE-KING 5 08-16-2008 12:30
sagem 226 after unlock now is dead MOBIFEMI FuriousGold 7 04-09-2008 21:46
6280 after few trys now is dead ayubalikhan BB5BOX 13 12-20-2007 22:44
L6 after full flash now is dead? makkah mobile Smart-Clip 15 11-07-2007 10:50
Page generated in 0.35154 seconds with 8 queries
