09-18-2017, 11:33 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | After CM2 New Activation On Infinity CDMA Update Frimware Stuck..Check Pls Now Showing This Error === DongleManager [Infinity] v1.70 [18-09-2017 15:52:02] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 01069C7808B51292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.70 [18-09-2017 15:52:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 01069C7808B51292 === Process started: 18-09-2017 15:52:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Last edited by CRM; 09-18-2017 at 11:41. |
09-18-2017, 14:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | If you have purchased New CM2 activation, Just do as follows Don't try to update the card again and again, It will block your update attempt. Wait for Infinity supporters or Contact http://www.infinity-box.com/support/?r=2 for faster response.. |
09-18-2017, 14:04 | #3 (permalink) |
09-18-2017, 19:42 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
