01-01-2009, 14:02 | #1 (permalink) |
Insane Poster Join Date: Aug 2007 Age: 43
Member: 575824 Status: Offline Thanks Meter: 4 | after safe formate chinees letters appeard can some one please help me regarding this thank you. COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7420:C61C Connecting, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 109 sec Remove/Install battery now ! COM3 [VCP1] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7420:C61C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 086092_601_V9041 Version: NEOTEL26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35xxxxxxxxxxxxx connection Ok building list... done items to clear: 175 warning: wrong packet cs items cleared: 155 of 175 building list... done items remains: 0 Finished, time used: 117 sec Remove/Install battery now ! |
01-01-2009, 16:49 | #3 (permalink) |
Member: 575824 Status: Offline Thanks Meter: 4 | no brother this phone not working only show one strange language in the display after welcome note cannot input any thing when type any key only here key sound cannot go to menu cannot celibate....i don't understand this thank you for your help |
01-02-2009, 10:34 | #6 (permalink) |
Member: 575824 Status: Offline Thanks Meter: 4 | thank you very much i did celebration but now can switch on then only one or two times keys work then the phone is struck even cannot switch off also.... any idea please? |
01-02-2009, 10:55 | #7 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | it looks like the Hardware problem do resold the processor and Flash Hope u will get it working. |
The Following User Says Thank You to .::BHATTI::. For This Useful Post: |
01-02-2009, 13:58 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try complete format, after that try to calibrate touchscreen by touchine with pen needed points on LCD. after you calibrated touchscreen- type *#0044# to set english language. then check phone behavior |
n95 can not complat safe formatting | soshan | SpiderMan | 0 | 10-18-2009 17:06 |
chinese 1600 bad software after safe format | azeem781986 | Infinity-Box | 3 | 10-09-2009 19:14 |
NAND phone safe formated with NOR | Maiwand khan | Infinity-Box | 8 | 01-22-2009 19:58 |
Useing J.A.F com to format chines mobile | iraqi-i | Chinese Models & Cloned Phones | 1 | 12-24-2007 23:23 |
M618 no luck after safe and complete format | ..::ApexComm::.. | Infinity-Box | 0 | 11-28-2007 14:05 |
