after unlock k200 cant save images i try whit all ffs repair and cant work i uploaded the backup of eprom and flash of this phone help me to solve the problem i make flash.flex.format and same problem http://rapidshare.com/files/68111926/k200_camera.rar.html |
Hello, Please, next time make clear explanation of problem but not false explanation (like this time). "Camers save" problem is NOT related with unlock, it's just a standard bug of this cheap phones. How to solve it: Infinity-Box How to repair SE-K200i SE-K220i "Camera not save" 1. Run software 2. Go to "Flash" page 3. Uncheck "Firmware" box 4. Uncheck "Flex" box 5. Check "Eeprom" box 6. Load repair eeprom file: K200i_repair_ffs_07.80E.bin or K200i_repair_ffs_0A.80E.bin 7. Uncheck "Format FFS" box 8. Press "Write" button 9. Follow instructions in software log window |
i tell you i used all repair ffs and not work i and its not a bug of this phone its a brand new phone and give this problem after unlock whit infinitybox and i have 2 phones whit same problem you could help me to solve this problem i tried the procedure if you follow and sorry for my english of first post |
Dear Friend. I just want to repeat: Infinity-Box unlock method can't be a reason of this problem. If you have original flash backup (as I can see you have uploaded something to rapidsaher) you can restore it and see results. So, what is phone state after you restore original backup files ? |
ok if you cant help me i solve my problem by my self using another tool but i tell i never have problem whit infinity software i have a 2 years ago and in my opinion its a great box but the unlock procedure of k200 phone is not consistent in my case about 15 phones of all i unlocked returned whit problems restarting or freeze at log sony or cant save images of camera so all the best for you and the backup what i make its after the problem before this i tested the phone by my self and all ok |
Thank you very much for info. I still can't beleive that this problem is a result of unlock process. This problem can be a result of "format/reset" in some cases, but as per unlock - I am not sure. Anyway, I'll double check software but also I recommend you try to use repair eeprom files and try to repair phone. Some info: power-on phone w/o sim card press * key 3 (three) times scroll to end of page and see "File System" mesage. What you can see there after you have used different eeprom files ? Also it's good idea to post here (or maybe better to send to [email protected]) "operation.log" file from HModule folder (in fact t's the first step that yopu must do if you have any problems because there we can see detailed software operations steps). Btw, did you really tested brand new phones before unlock and tried to make photos with it ? It's really important to know this for me to see where is the problem. If yes, how many phones was tested and waht operations was tested ? Finally, of course, you are free to use any other tool to unlock/repair your phone, but please, if you will post here more info about your phones story with other tool (repaired or not etc.), please, no need to post here name of other tools due to here is Infinity-Box suppot forum. |
for example i unlocked one now whitout problem and everything is fine COM2 [VCP0] selected Device: Sony-Ericsson K200i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb version sw: R1AB003 version sw: CXC1250814 version flex: CDA102773/1 imei: 35871701000794 Check flash Done Check parameters... reading Sony-Ericsson K200i_35871701000794_eeprom_calibration-1... file saved: backup_Sony-Ericsson K200i_35871701000794_eeprom_calibration-1_20071108-173029.80E.bin reading Sony-Ericsson K200i_35871701000794_eeprom_calibration-2... file saved: backup_Sony-Ericsson K200i_35871701000794_eeprom_calibration-2_20071108-173030.80E.bin Check parameters Done Check data... Check data Done Writing... flash: 01227E22212200:46237300000000 Write: eeprom flash: 01227E22212200:46237300000000 Write: eeprom .... .... .......... locks cleared Writing Done Finished, time used: 60 sec Remove/Install battery now ! after unlock i tested and all ok include camera but the problem hapens days after process but not in all phones and in the flash files dont have this flash file i will post here backup of another phone for you put in folder because my language is portuguese brazil and i flashed the other phone portuguese of portugal here all phones is like this hw info: 22 11 900/1800 sw version: r1ab003 900/1800 cxc 1250814 cda 102773/1 r4a flash device: spansion flash file system: spansion file system thanks for the interest of my problem |
solution k200 camera Use of the xxxxxxx sw to unlock using the door of communication vygis or vpower 100% tested and had no more problems |
My congratulations ! You have increased your post counter today successfully. One thing: you just show your total zero knowledges. Yes, you know names of boxes but it's the only info that you have, you know nothing about phones, about repair and even about box functions, so please, continue your training in other place. Warmest regards ! p.s. when you have visited (if even visited) Vygis web site ? |
I have nothing against you, already has his box and swapped for better:) ================= dear gtcellrepair vygis box not support this model (k200i/220i) yet so becarefull |
@gtcellrepair My congratulations to you if you have used "vygis or vpower 100% tested and had no more problems" and found that it can unlock K200. My advice: please, visit Vygis site and see list of supported models. Good luck ! Thread closed, no reason to continue offtopic discussion. |
