Old 11-07-2007, 18:55   #1 (permalink)
Member: 434450
Thanks Meter: 51
after unlock k200 cant save images
i try whit all ffs repair and cant work i uploaded the backup of eprom and flash of this phone help me to solve the problem i make flash.flex.format and same problem
http://rapidshare.com/files/68111926/k200_camera.rar.html
Old 11-07-2007, 19:35   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Please, next time make clear explanation of problem but not false explanation (like this time).
"Camers save" problem is NOT related with unlock, it's just a standard bug of this cheap phones.
How to solve it:
Infinity-Box How to repair SE-K200i SE-K220i "Camera not save"
1. Run software
2. Go to "Flash" page
3. Uncheck "Firmware" box
4. Uncheck "Flex" box
5. Check "Eeprom" box
6. Load repair eeprom file: K200i_repair_ffs_07.80E.bin or K200i_repair_ffs_0A.80E.bin
7. Uncheck "Format FFS" box
8. Press "Write" button
9. Follow instructions in software log window
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-07-2007, 20:10   #3 (permalink)
Member: 434450
Thanks Meter: 51
i tell you i used all repair ffs and not work i and its not a bug of this phone its a brand new phone and give this problem after unlock whit infinitybox and i have 2 phones whit same problem you could help me to solve this problem i tried the procedure if you follow and sorry for my english of first post
Old 11-07-2007, 22:37   #4 (permalink)
Member: 130995
Dear Friend.
I just want to repeat: Infinity-Box unlock method can't be a reason of this problem. If you have original flash backup (as I can see you have uploaded something to rapidsaher) you can restore it and see results.
So, what is phone state after you restore original backup files ?
Old 11-08-2007, 19:02   #5 (permalink)
Member: 434450
Thanks Meter: 51
ok if you cant help me i solve my problem by my self using another tool but i tell i never have problem whit infinity software i have a 2 years ago and in my opinion its a great box but the unlock procedure of k200 phone is not consistent in my case about 15 phones of all i unlocked returned whit problems restarting or freeze at log sony or cant save images of camera so all the best for you and the backup what i make its after the problem before this i tested the phone by my self and all ok
Old 11-08-2007, 20:56   #6 (permalink)
Member: 130995
Thank you very much for info. I still can't beleive that this problem is a result of unlock process. This problem can be a result of "format/reset" in some cases, but as per unlock - I am not sure.
Anyway, I'll double check software but also I recommend you try to use repair eeprom files and try to repair phone.
Some info:
power-on phone w/o sim card
press * key 3 (three) times
scroll to end of page and see "File System" mesage. What you can see there after you have used different eeprom files ?
Also it's good idea to post here (or maybe better to send to I[email protected]) "operation.log" file from HModule folder (in fact t's the first step that yopu must do if you have any problems because there we can see detailed software operations steps).
Btw, did you really tested brand new phones before unlock and tried to make photos with it ? It's really important to know this for me to see where is the problem.
If yes, how many phones was tested and waht operations was tested ?
Finally, of course, you are free to use any other tool to unlock/repair your phone, but please, if you will post here more info about your phones story with other tool (repaired or not etc.), please, no need to post here name of other tools due to here is Infinity-Box suppot forum.
Old 11-08-2007, 21:45   #7 (permalink)
Member: 434450
Thanks Meter: 51
for example i unlocked one now whitout problem and everything is fine
COM2 [VCP0] selected
Device: Sony-Ericsson K200i
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot...
Press Power button now !
loading...
Boot Done
Check connection...
Check connection Done
Set baud...
Set baud Done
Check flash...
flash: 01227E22212200:92EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
version sw: R1AB003
version sw: CXC1250814
version flex: CDA102773/1
imei: 35871701000794
Check flash Done
Check parameters...
reading Sony-Ericsson K200i_35871701000794_eeprom_calibration-1...
file saved: backup_Sony-Ericsson K200i_35871701000794_eeprom_calibration-1_20071108-173029.80E.bin
reading Sony-Ericsson K200i_35871701000794_eeprom_calibration-2...
file saved: backup_Sony-Ericsson K200i_35871701000794_eeprom_calibration-2_20071108-173030.80E.bin
Check parameters Done
Check data...
Check data Done
Writing...
flash: 01227E22212200:46237300000000
Write: eeprom
Write: eeprom
locks cleared
Writing Done
Finished, time used: 60 sec
Remove/Install battery now !
after unlock i tested and all ok include camera but the problem hapens days after process
but not in all phones and in the flash files dont have this flash file i will post here backup of another
phone for you put in folder because my language is portuguese brazil and i flashed the other phone portuguese of portugal
here all phones is like this
hw info:
22 11 900/1800
sw version:
r1ab003 900/1800
cxc 1250814
cda 102773/1 r4a
flash device:
spansion flash
file system:
spansion file system
thanks for the interest of my problem
Old 11-10-2007, 00:49   #8 (permalink)
gtcellrepair's Avatar
Member: 80368
Thanks Meter: 32
Thumbs up solution k200 camera
Use of the xxxxxxx sw to unlock using the door of communication vygis or vpower 100% tested and had no more problems
Last edited by InfinitySupport; 11-10-2007 at 00:55. Reason: unwanted name replaced
Old 11-10-2007, 00:58   #9 (permalink)
Member: 130995
My congratulations ! You have increased your post counter today successfully.
One thing: you just show your total zero knowledges. Yes, you know names of boxes but it's the only info that you have, you know nothing about phones, about repair and even about box functions, so please, continue your training in other place.
Warmest regards !
p.s.
when you have visited (if even visited) Vygis web site ?
Old 11-14-2007, 23:50   #10 (permalink)
Member: 80368
Thanks Meter: 32
Thumbs down
I have nothing against you, already has his box and swapped for better
dear gtcellrepair
vygis box not support this model (k200i/220i) yet so becarefull
Old 11-15-2007, 00:11   #11 (permalink)
Member: 130995
@gtcellrepair
My congratulations to you if you have used "vygis or vpower 100% tested and had no more problems" and found that it can unlock K200.
My advice: please, visit Vygis site and see list of supported models.
Good luck !
Thread closed, no reason to continue offtopic discussion.
K200 not save pictures after flash????? svchost Infinity-Box 8 02-14-2012 10:40
730sc after unlock and patch cam cant save pictures daveiant UST Pro II 4 08-26-2009 12:31
Sonyericsson K200 dead after unlock mulenga MT-BOX 2 06-10-2008 20:02
F700v after Unlock canīt save Pic ?? ExTeem-Unlocker UST Pro II 2 05-06-2008 09:14
help se k200 can't save picture gnscr76 Sony Ericsson 1 11-09-2007 12:17
Page generated in 0.38799 seconds with 8 queries
