06-07-2011, 16:47 | #1 (permalink) |
Insane Poster Join Date: Feb 2009 Location: Phnom Penh
Member: 961882 Status: Offline Sonork: 123456789 Thanks Meter: 1 | After Unlock it show Insert sim card module v3.82 Device: Hello-HL2802 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware ZTE-R221_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.SEP-MOVI-R8SM-P109A17V1_0_0B01_2010-12-16_En_Es_Movistar-Urban.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5F16:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: C2227E22212201:2AEA0000000000 flash: AMD/Fujitsu std [def 0080x020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-HL-R9DM-P109A21V1_0_0B05.BIN project-id: CB-HL-R9DM-P109A21V1.0.0B05, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Hello-HL2802_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-HL-R9DM-P109A21V1_0_0B05__ffs... file saved: C:\InfinityBox\MModule\Hello-HL2802_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-HL-R9DM-P109A21V1_0_0B05__ffs_20110607-223109.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (general #0)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: C2227E22212201:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 12 min 9 sec Remove/Install battery now ! Pls help me about this after write it to unlock it show insert in card or do you have another flash file for this model. Thanks in advance. |
06-08-2011, 13:52 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | First of all don't use old modules, always check for updates and install latest modules for best results. Did you have original full backup of phone? Try to flash phone with different firmwares of zte-R221 and check result. Wr. |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
