Old 10-03-2009, 10:44   #1 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 97
new firmware, strange case
I can read it from phone, but if i write it back, phone not start up.
http://rapidshare.com/files/28808373...125903.B0M.bin
here is the log:
COM16 [VCP1] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
editor_corrected_TELSDA25_07B_PCB01_GPRS_MT6225_S0 0.MAUI_07B_W08_16_MP_V5_F1__fullflash_20091003-125903.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0B03:0006
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: C25498A6
rom info protocol ver: 04
ver. sw 1: TELSDA25_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16 _MP_V5_F1.BIN
ver. sw 2: MAUI.07B.W08.16.MP.V5.F1, FCE4DA66
ffs offset/size: 00E00000/00200000
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
startup code area #1 check...
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.C25498A6.[TELSDA25_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16 _MP_V5_F1.BIN_99251B03].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.C25498A6._TELS DA25_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16_MP_ V5_F1.BIN_99251B03_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C25498A6.[TELSDA25_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16 _MP_V5_F1.BIN_99251B03].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.C25498A6._TELSDA25_07B_PCB01_GPRS_MT6225_S00.MAU I_07B_W08_16_MP_V5_F1.BIN_99251B03_.rpl
warning: unknown rom info structure: TELSDA25_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16 _MP_V5_F1.BIN_99251B03
error: Unknown firmware detected (v.2.91, database date: unknown), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
detecting startup code area #2...
startup code area #2 is absent
You can flash phone now but can not finalize it.
In most cases phone CAN NOT power-on.
Do you want to continue anyway ?
aborted by user
Finished, time used: 23 sec
Remove/Install battery now !
Old 10-03-2009, 22:19   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
was phone working before taking backup?
did you check battery voltage now? it should be more than 3,7v
Old 10-04-2009, 13:05   #3 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 97
Yes, sure. I had quantity identical (firmware and form) phones, but 3 of them can't power on after flashing even their own backup.
Old 10-04-2009, 21:27   #4 (permalink)
Member: 148515
hello!
i will check your file, be patient
Old 10-05-2009, 23:56   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@domestik
Mkae "enhanced security fix" disabled and flash phone again.
What is the results ?
Also, if you have the same good working phone, read flash again with latest ChineseMiracle v2.93 and send full flash again to [email protected]
Old 10-12-2009, 20:07   #6 (permalink)
domestik's Avatar
Member: 40118
Thanks Meter: 97
Did as you said, but no luck. Flashing frimware from support - same thing ("Cannot finalize").
Old 10-12-2009, 20:58   #7 (permalink)
Member: 148515
hello!
you must wait for new release of CM
Need unlock code for VDF136 new firmware here is dump. azeem781986 FuriousGold 16 05-26-2010 04:48
New firmware and strange problem domestik Infinity-Box 4 11-16-2009 14:04
6510 strange case medo Nokia Digital Core Technology 4 ( DCT-4 ) 5 09-30-2003 17:14
6510 strange case medo Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-03-2003 17:06
Strange case... t18s won't unlock s608858 Old Ericsson Phones & Sony Phones 9 09-04-2001 21:26
Page generated in 0.18644 seconds with 9 queries
