01-18-2009, 13:53 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: PATTAMUNDAI
Member: 508774 Status: Offline Sonork: 100.1590207 Thanks Meter: 207 | after unlock vodafone 226 fm key pad not work ? before ublock key works but now key pad not work ? need help to fix this problem plz here is unlock log COM3 [VCP0] selected module v1.60 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20090118-172628.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20090118-172629.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20090118-172634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20090118-172640.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! 226 fm flash file not avalable in infinity support site ? |
01-19-2009, 13:20 | #5 (permalink) |
Member: 508774 Status: Offline Sonork: 100.1590207 Thanks Meter: 207 | thats i know . but beforu key work fine ? with out sim & with sim 1 3 7 key work other key press any key * (star) symbol show ? need help |
08-04-2009, 17:47 | #9 (permalink) |
Junior Member Join Date: Jun 2006
Member: 300590 Status: Offline Thanks Meter: 7 | I found flash file maby u can try.dont ask me how to use it. http://rapidshare.com/files/150583783/226_FM.rar |
10-13-2009, 09:00 | #10 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | [QUOTE=milandhal;4070615]after unlock vodafone 226 fm key pad not work ? before ublock key works but now key pad not work ? need help to fix this problem plz here is unlock log COM3 [VCP0] selected module v1.60 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20090118-172628.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20090118-172629.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20090118-172634.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20090118-172640.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 44 sec Remove/Install battery now ! ITS 100% UNLOCK & NO KEYPAD PROBLEM COM3 [VCP2] selected module v1.68 Device: Vodafone-226FM Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IE 211207_1322 EDI_IE_211207_1322 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20091013-131018.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20091013-131024.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20091013-131031.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_lock-area_20091013-131041.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 62 sec Remove/Install battery now ! |
3110c key pad not work after 24 haur | rohit50 | Nokia Hardware & Hardware Repair | 0 | 07-19-2009 08:42 |
V3T-KEY PAD NOT WORKING-after unlock | udai | Smart-Clip | 1 | 05-30-2009 10:53 |
vodafone 225 after unlocked key pad not work | ruvanw1979 | Infinity-Box | 8 | 06-07-2008 17:35 |
5510 down key pad not working plz help | mohammed | Nokia Hardware & Hardware Repair | 3 | 04-07-2005 21:04 |
Gd 92 key pad not working | GSM RAJ | Hardware Repair by brands | 1 | 12-13-2002 18:35 |
