-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   After unlocked vodafone 340 now is DEAD (http://forum.gsmhosting.com/vbb/f296/after-unlocked-vodafone-340-now-dead-1200256/)
godwin 02-03-2011 12:35
pls infinity team i need help to solve my dead phone after unlocked.
i unlocked it using smart fast method and i got this error
COM1 [VCP0] selected
module v3.72
Action: "sp-unlock"
unlock method: smart fast
Model: Vodafone-340
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:2F03:A003
status: 01
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.15.M00.02.39
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 35592203210311
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
reading data #2...
error: verification failed
what to do:
1. be sure that you have full flash backup for emergency case
2. make "format ffs" in "complete" mode
3. power-on phone
4. power-off phone by "Power" button (DO NOT remove battery)
5. repeat current operation
error: operation failed !
Finished, time used: 17 sec
Remove/Install battery now !
And i used standard fast method after sucessfully done now the phone is dead.I flash the backup,firmware at the support site and i read flash from different phone to flash it but still DEAD.
i think i was using low version and i download the latest one and i flash it with all the files again but still DEAD.
here is the flash logs with the latest version
COM12 [VCP0] selected
module v3.73
Device: Vodafone-340
Action: write flash
"smart write" active
write: Firmware
Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42_2010-01-11_En.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is absent
startup code area #1 record #1 is damaged, recalculation required
rom info detection finished
device-id: 1E1020AF
rom info ver: 05
sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BINIuthQ
project-id: $6cZ%.i?OKH<`TzAp-V,KKL, 9813EDE8
code offset: 00000000
ffs offset/size [B7]: 0E27AC09/F7982630
TCL-ID is absent
ffs/eeprom address assigned: 0E27AC09
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
usb bootloader (file) is absent
startup code area #1 check...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42.BINIuthQ__system_log_1E1020AF_E8ED139 8_20110203-114730.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
security area (sec info, cust) calculation...
identification header detected
customization detected: BM35A1X1
customization: BM35A1X1
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN
use default security area (sec info, hash) pattern
error: can't assign default hash address range for ffs 00B80000/00001000
error: security area (sec info, hash) size is too small: 0000
error: can't calculate security area (sec info, hash)
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42.BINIuthQ__system_log_1E1020AF_E8ED139 8_20110203-114814.B0X.bin
Finished, time used: 1 min 32 sec
After flash i FORMART FFS and REPAIR SECURITY EREA
BUT STILL DEAD
InfinitySupport 02-03-2011 12:46
Hello,
As I can see, some data from phone can not be read well.
It may be 2 reasons:
1. empty battery
2. damaged phone hardware, probably you need to reball/rehot flash chip and/or cpu chip
Please, check both.
godwin 02-03-2011 15:23
Originally Posted by InfinitySupport (Post 6911077)
Hello,
1. empty battery
Please, check both.
Pls i used full battery to flash it but still dead and am asking where can i found FLASH CHIP and CPU CHIP in the phone
thank u
drbilal 03-04-2011 12:43
hellooo infinity
my 2 hanset vodafone 340 unlock after daed
plese helpe.................
InfinitySupport 03-04-2011 22:38
Originally Posted by drbilal (Post 7031245)
hellooo infinity
What you have tried to do with phones exactly ?
post here operation logs
Dwight07 08-29-2011 17:38
vodafone 340 dead repaired
I did the same unlock and after the phone did not power up but i downloaded flash file Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin
Flash the phone and phone power up but screen blurry
COM2 [VCP0] selected
module v4.01
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
enhanced security fix enabled
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:EC03:A00D
status: 01
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: [standard] type (05)
TCL-ID is absent
rom info ver: 05
sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN
project-id: BM35A1.V2.22.M00.02.44, 00000000
ffs offset/size [01]: 00B80000/00480000
TCL-ID is absent
ffs/eeprom address assigned: 00B80000
area1 is valid
area2 is valid
area3 is valid
area4 is valid
reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs...
file saved: C:\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs_20110829-110249.B0E.bin
====> Write ...
done
file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110829-110308.B0X.bin
Area: Firmware
Write: Firmware
..................region counter set: 01
security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Write Done
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110829-111017.B0X.bin
Finished, time used: 9 min 38 sec
YellowBoss 08-30-2011 03:29
post here operation logs for operations that was done.
Dwight07 08-30-2011 16:45
I tried to unlock the phone and it fail to power after so i tried the flash files in the support area and that one worked.
Did not save the unlock log, sorry.
khoykhoy20 02-14-2012 11:45
vodafone 340
xxxxx
sn b34000a600fc019l
unlock code???????????????
YellowBoss 02-14-2012 14:05
Originally Posted by khoykhoy20 (Post 8149825)
vodafone 340
xxxxx
sn b34000a600fc019l
Please, next time post this kind of requests in correct forum section.
Thank you !
MGT SOFTWARE 02-15-2012 14:21
just restore with original back up
Emmanuel Ankah 02-15-2012 14:44
you may be chosen wrong model for unlock 340 flash the phone will be OK don't panic
Emmanuel Ankah 02-15-2012 14:45
where are you located? l may help
Page generated in 0.27365 seconds with 5 queries
