02-03-2011, 13:35 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | After unlocked vodafone 340 now is DEAD i unlocked it using smart fast method and i got this error COM1 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2F03:A003 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.15.M00.02.39 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203210311 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... reading data #2... error: verification failed what to do: 1. be sure that you have full flash backup for emergency case 2. make "format ffs" in "complete" mode 3. power-on phone 4. power-off phone by "Power" button (DO NOT remove battery) 5. repeat current operation error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! And i used standard fast method after sucessfully done now the phone is dead.I flash the backup,firmware at the support site and i read flash from different phone to flash it but still DEAD. i think i was using low version and i download the latest one and i flash it with all the files again but still DEAD. here is the flash logs with the latest version COM12 [VCP0] selected module v3.73 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42_2010-01-11_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2F03:A003 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 1E1020AF rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BINIuthQ project-id: $6cZ%.i?OKH<`TzAp-V,KKL, 9813EDE8 code offset: 00000000 ffs offset/size [B7]: 0E27AC09/F7982630 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 0E27AC09 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42.BINIuthQ__system_log_1E1020AF_E8ED139 8_20110203-114730.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN use default security area (sec info, hash) pattern error: can't assign default hash address range for ffs 00B80000/00001000 error: security area (sec info, hash) size is too small: 0000 error: can't calculate security area (sec info, hash) Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42.BINIuthQ__system_log_1E1020AF_E8ED139 8_20110203-114814.B0X.bin Finished, time used: 1 min 32 sec Remove/Install battery now ! After flash i FORMART FFS and REPAIR SECURITY EREA BUT STILL DEAD |
02-03-2011, 13:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see, some data from phone can not be read well. It may be 2 reasons: 1. empty battery 2. damaged phone hardware, probably you need to reball/rehot flash chip and/or cpu chip Please, check both. |
02-03-2011, 16:23 | #3 (permalink) | |
Member: 153893 Status: Offline Thanks Meter: 266 | Quote:
thank u | |
08-29-2011, 17:38 | #6 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | vodafone 340 dead repaired I did the same unlock and after the phone did not power up but i downloaded flash file Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin Flash the phone and phone power up but screen blurry COM2 [VCP0] selected module v4.01 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 23_M00_02_35_En_Nl_Fr_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EC03:A00D status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_44.BIN project-id: BM35A1.V2.22.M00.02.44, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs... file saved: C:\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__ffs_20110829-110249.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110829-110308.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................region counter set: 01 security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_44__system_log__00000000_20110829-111017.B0X.bin Finished, time used: 9 min 38 sec Remove/Install battery now ! |
08-30-2011, 16:45 | #8 (permalink) | |
Member: 642071 Status: Offline Thanks Meter: 54 | Quote:
Did not save the unlock log, sorry. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
