09-03-2011, 22:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: morocco Age: 47
Member: 1000191 Status: Offline Sonork: 100.1616164 Thanks Meter: 471 | after unlocking G7010 Software error :4 after unlocking G7010 Software error :1 after first time flashing Software error:4 after changing files flashed Software error:23 bellow logs of last time flashing how to fix it can you please help me thank you without sim everthing is working fine no error with sim i get above error if i turn it on without Sim it will work with no error with sim i get above problems COM3 [Serial3] selected module v4.01 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 46SSC.BIN_FLNTY6701111184KC_Nov-04-2010_En_Es.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Huawei-G7010_ffs_08.ESPC113B146SSC.BIN_FLNTY6701111184KC. B0E.bin nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ESPC113B146SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B146SSC. BIN_FLNTY6701111184KC project-id: ESPC113B146SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 2 loading files... number of areas: 2 done write... write core... Format... autodetection mode... Format done Disconnect... done Finished, time used: 6 min 13 sec Remove/Install battery now ! |
09-04-2011, 08:27 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
11-07-2011, 16:20 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, 1. restore original eeprom (or full flash backup) 2. use this software: http://forum.gsmhosting.com/vbb/f296...eased-1377414/ |
11-10-2011, 23:46 | #5 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: . Age: 35
Member: 400280 Status: Offline Thanks Meter: 83 | Quote:
sir... I have a question.... I have 1 g7010 with error 23 but I haven't the backup.... because I didn't the process unlock.... I try read backup of other g7010 good and input in bad g7010... unlock ok but now software error 4.. after I do format ffs and now i get error 23... and I try unlock again and now "error FAT.........." If I cannot get the original backup.... The phone killed forever?? (for now). ??? | |
The Following User Says Thank You to Medusin For This Useful Post: |
11-17-2011, 21:37 | #8 (permalink) | |
Please, answer friend... P.S. We do not insist. you can but (if you want) or you can not buy (if you do not want) Infinity-Box products. | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
