10-03-2016, 11:06 | #1 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | After update CM2MTK plobrem spd and rda and mtk 1.55 .1.54 ...application are open need solution 1-install CM2MTK 1.57 2-update Dongle manger 3- open CM2MTK 1.57 4-select cpu close application CM2MTK 1.57 and 1.56 but 1.55 work is ok uninstall and reinstall |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
10-03-2016, 11:07 | #2 (permalink) | |
What is your Support Validity Date ? How to check - Infinity-Box - FAQ (Frequently Asked Questions) If you have active support - run DongleManager and update Box/Dongle firmware. If your support is not active - renew support first. DongleManager is here - Index of pub/ | |
10-03-2016, 11:12 | #3 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2590772 Status: Offline Thanks Meter: 10 | good dr_moosavi ==== [03/10/2016 10:57:41] ==== Scanning... Box/Dongle found: Main Infinity-Box/Dongle HWID: 0000************** Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 03/10/2016 10:57:57 ---------- DongleManager [Infinity-Box] v1.66 [03/10/2016 10:57:57] PC HWID: BF844668************* Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000********** Type: Main Infinity-Box/Dongle S/N: C******* Version: 0132.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed ---------- Process finished: 03/10/2016 10:58:29 ---------- DongleManager [Infinity-Box] v1.66 [03/10/2016 10:58:29] PC HWID: BF844668C3E************** Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000*********** Box/Dongle Serial No (S/N): C******** Firmware version: 0134.02 => Activations: - 00: Main Infinity-Box/Dongle v.0134 |
10-04-2016, 07:13 | #4 (permalink) | |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Quote:
Code: Token - Type: Infinity-Box/Dongle - Account Status: Active - Hardware Status: Ok Services - Activation 1: Infinity-Box/Dongle; S/N: D*****; Firmware Version: 0134; Registered: 2016-04-26; Expired: 2017-04-26; Support: Active - More Services may be active but not listed | |
10-04-2016, 07:26 | #5 (permalink) | |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | SPD and RDA and MTK 1.55 .1.54 ...application are open but 1.57 application are open select cpu close application CM2MTK 1.57 and 1.56 but 1.55 1.54 good work Quote:
10-05-2016, 00:50 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity software do not works if you have flexihub running, it's a software conflict. so pls select and run only one of them |
10-06-2016, 18:57 | #11 (permalink) | |
select cpu close application CM2MTK 1.57 and 1.56 1.58 but 1.55 work is ok install new windows7 select cpu close application CM2MTK 1.57 and 1.56 1.58 but 1.55 1.54 work is ok other Infinity-Box mtk 1.57 update smart card error | |
10-07-2016, 04:13 | #13 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ˇˇInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Maybe is DEL "fault.bin" soft open OK.... Try Update again the dongle.... |
The Following User Says Thank You to maomatrix For This Useful Post: |
10-20-2016, 16:44 | #14 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | "fault.bin" send to support by mail delet "fault.bin" application working but After install CM2QLM fault.bin comback InfinityBox CM2QLM is not working CM2MTK v1.58 and CM2QLM Not Open (fault.bin) Open CM2 MTK All Work But After Select SP : Auto [2601] [6571...6595] [6732...6797] [81/83/87xx] NAND / Emmc Software Close And CM2 Not open after that in CM2 folder One file come Its Name (fault.bin) deleted but coming again deleted all cm2 folder and instal again but some story |
10-20-2016, 16:47 | #15 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
