02-02-2017, 11:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | After update CM2QLM 1.10 - [0031] Dongle identification data damaged. It does not start Then I installed the old version CM2QLM 1.09 And now all the software Infinity does not work. The key is not updated. What's up ? Code: Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 02.02.2017 11:24:44 ---------- DongleManager [Infinity-Box] v1.67 [02.02.2017 11:24:44] PC HWID: C2DAAF1CE04E0E38F408FA1CC0A5815A Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00021231FF021*** Type: Main Infinity-Box/Dongle S/N: ******* Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
02-02-2017, 11:44 | #2 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | Your dongle is blocked it's software or device driver fault To solve this problem First you fresh windows to PC Now download dongle manager Run it Your problem is solved Sent from my XT1058 using Tapatalk |
02-02-2017, 12:01 | #3 (permalink) | |
Member: 1558427 Status: Offline Thanks Meter: 630 | Quote:
Code: Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 02.02.2017 12:57:33 ---------- DongleManager [Infinity-Box] v1.67 [02.02.2017 12:57:33] PC HWID: 474E21D9F8846E32E50AAF44EE4F6103 Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00021231FF021982 Type: Main Infinity-Box/Dongle S/N: 1A**** Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 Same. | |
02-02-2017, 15:38 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Do you have another card reader? Insert smart card into some other card reader and try to upgrade only once. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
02-02-2017, 16:25 | #7 (permalink) | ||
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Wait for respected YellowBoss or InfinityHelp for further instructions Quote:
Don't answer nonsense if you have no idea. Br. Infinity Box Team. | ||
02-02-2017, 16:50 | #9 (permalink) |
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | This is officially done by yellow boss In this tread given below http://forum.gsmhosting.com/vbb/f296.../#post11325495 And sorry for for that |
02-02-2017, 17:19 | #10 (permalink) | |
In CM2 folder not file named fault.bin | |
02-03-2017, 23:14 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Well... Today you hve made 6 more attacks. Why do you want to kill your dongle permanently ? Now your account locked by server again for 24 hours due to security reason. If your dongle is blocked you should wait 24 and then follow this instruction - http://www.infinity-box.com/support/?r=4 |
