Old 09-10-2018, 11:15   #1 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
after write backup phone hang on logo
Card found : 7DB1869C , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Read Flash [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 652 [MSM8952]
ID_BLOCK_S : 0045679E
ID_BLOCK_E : 00000001
ID_BLOCK_L : 9BC857592C51F6CEE66F8CFB73CA4724
ID_BLOCK_L : FADE80B096FC5E6CBE9FD95E6E5652FE
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Brand : LeEco
ProdName : Le2_NA
Device : S2
AndroidVer: 6.0.1
Manufact. : LeMobile
QLMxCPU : MSM8952
QLMxPRJ : IFXNAOP5802102141S
DevInfo : MSM8952__LeMobile__LeEco__ANDR_v6.0.1__S2__Le2_NA_ _IFXNAOP5802102141S
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : adspso.bin
[Read Ok] : ddr.bin
[Read Ok] : fs_gc.img
[Read Ok] : sec.dat
[Read Ok] : splash.img
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : persist.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : misc.img
[Read Ok] : recconf.cfg
[Read Ok] : leconf.img
[Read Ok] : mdtp.img
[Read Ok] : cmnlib.mbn
[Read Ok] : keymaster.mbn
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8976 / eMMC
Firmware Size : 4406 MiB
Done!
Elapsed: 00:09:41
Reconnect Power/Cable!
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:20
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : LeEco
Device Manufact.: LeMobile
Device Model : S2
Device CPU : MSM8952
Device IntName : Le2_NA
Device Version : 6.0.1
CU_SWVer : LeMobile
Device Compile : 2/13/2017 11:07:15 PM
Device Project : IFXNAOP5802102141S
Load Ok!
Operation : Flash [ v1.16 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Boot Ok!
Flash Chain : 58
Flashing now
Flashing : gpt_main0.bin
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : adspso.bin
Flashing : sec.dat
Flashing : splash.img
Flashing : emmc_appsboot.mbn
Flashing : boot.img
Flashing : recovery.img
Flashing : persist.img
Flashing : system.img
Flashing : cache.img
Flashing : misc.img
Flashing : recconf.cfg
Flashing : leconf.img
Flashing : mdtp.img
Flashing : cmnlib.mbn
Flashing : keymaster.mbn
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:06:04
Old 09-10-2018, 11:41   #2 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
need hellp me plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 09-10-2018, 12:27   #3 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
stock rom neeeed plzzzzzzzzzzzzzzzzzzzzzzzzz
Old 09-11-2018, 06:54   #4 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
plzz need ans me...........................
Old 09-11-2018, 07:01   #5 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
hi
sorry for late reply
download this file and flash it and check
i hope your problem will be solved
https://mega.nz/#!hoAxVSoR!VYuKEG9v-...bnfmh8kG-e1fEA
Old 09-11-2018, 09:46   #6 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
Originally Posted by kamal_singla View Post
hi
Loading 1 program definition file(s) ...
Firmware load error!
Firmware damaged or in unknown format! Send report to support!
plzzzzz hellp me bro
Old 09-11-2018, 09:47   #7 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
need slution plzzz hellp hellp
Old 09-11-2018, 09:52   #8 (permalink)
Member: 2211790
Thanks Meter: 5,118
flash it with qfil and check
Old 09-11-2018, 09:59   #9 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
Validating Application Configuration
Load APP Configuration
COM:-1
PBLDOWNLOADPROTOCOL:0
PROGRAMMER:True
PROGRAMMER:C:\Users\alimobile\Desktop\s2_india_spa rse_images\prog_emmc_firehose_8976_ddr.mbn
SEARCHPATH:C:\Users\alimobile\Desktop\s2_india_spa rse_images
RAWPROGRAM:
rawprogram0.xml
PATCH:
patch0.xml
ACKRAWDATAEVERYNUMPACKETS:False
ACKRAWDATAEVERYNUMPACKETS:100
MAXPAYLOADSIZETOTARGETINBYTES:False
MAXPAYLOADSIZETOTARGETINBYTES:49152
DEVICETYPE:eMMC
PLATFORM:8x26
VALIDATIONMODE:0
RESETAFTERDOWNLOAD:False
MAXDIGESTTABLESIZE:8192
SWITCHTOFIREHOSETIMEOUT:30
RESETTIMEOUT:200
RESETDELAYTIME:2
FLATBUILDPATH:C:\
FLATBUILDFORCEOVERRIDE:True
QCNPATH:C:\Temp\00000000.qcn
QCNAUTOBACKUPRESTORE:False
SPCCODE:000000
ENABLEMULTISIM:False
Load ARG Configuration
Validating Download Configuration
Image Search Path: C:\Users\alimobile\Desktop\s2_india_sparse_images
RAWPROGRAM file path: C:\Users\alimobile\Desktop\s2_india_sparse_images\ rawprogram0.xml
PATCH file path:C:\Users\alimobile\Desktop\s2_india_sparse_im ages\patch0.xml
Programmer Path:C:\Users\alimobile\Desktop\s2_india_sparse_im ages\prog_emmc_firehose_8976_ddr.mbn
Process Index:0
Start Download
Program Path:C:\Users\alimobile\Desktop\s2_india_sparse_im ages\prog_emmc_firehose_8976_ddr.mbn
Binary build date: May 13 2015 @ 14:41:37
QSAHARASERVER CALLED LIKE THIS: 'C:\Users\alimobile\Desktop\tools\Qualcomm_Flash_I mage_Loader_v2.0.0.5\QSaharaServer.exe -p \\.\COM660 -s 13:C:\Users\alimobile\Desktop\s2_india_sparse_imag es\prog_emmc_firehose_8976_ddr.mbn 'Current working dir: C:\Users\alimobile\AppData\Roaming\Qualcomm\QFIL
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: C:\Users\alimobile\Desktop\s2_india_sparse_images\ prog_emmc_firehose_8976_ddr.mbn
13:58:29: Requested ID 13, file: "C:\Users\alimobile\Desktop\s2_india_sparse_images \prog_emmc_firehose_8976_ddr.mbn"
13:58:29: 349548 bytes transferred in 0.281000 seconds (1.1863MBps)
13:58:29: File transferred successfully
NOTE: Target requested image 13 which is DeviceProgrammer. Forcing QUIT. This is by design, ** All is well ** SUCCESS!!
13:58:29: Sahara protocol completed
Sending Programmer Finished
Switch To FireHose
Wait for 3 seconds...
Max Payload Size to Target:49152 Bytes
Device Type:eMMC
Platform:8x26
Disable Ack Raw Data Every N Packets
Skip Write:False
Always Validate:False
Use Verbose:False
Download Fail:FireHose Fail FHLoader Fail:The system cannot find the file specified
Finish Download
Old 09-11-2018, 10:02   #10 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
not don plzzzzzzzzzzzzzzzzzzz other firmware
Old 09-11-2018, 10:06   #11 (permalink)
Member: 2211790
Thanks Meter: 5,118
i have only this firmware
btw, i sent link of all letv Indian models firmware check there
Old 09-11-2018, 10:46   #12 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
after use flashone tool don
thanx bro realy thanx
Load APP Configuration COM:-1
RAWPROGRAM:
rawprogram0.xml
PATCH:
patch0.xml
DEVICETYPE:eMMC
PLATFORM:8x26
VALIDATIONMODE:0
RESETTIMEOUT:200
RESETDELAYTIME:2
FLATBUILDPATH:C:\
SPCCODE:000000
COM:2
SAHARA:True
SAHARA:C:\Users\alimobile\Desktop\FlashOne1.9\s2_i ndia_sparse_images\prog_emmc_firehose_8976_ddr.mbn
SEARCHPATH:C:\Users\alimobile\Desktop\FlashOne1.9\ s2_india_sparse_images
RAWPROGRAM:
rawprogram0.xml
PATCH:
patch0.xml
MAXPAYLOADSIZETOTARGETINBYTES:True
DEVICETYPE:eMMC
SWITCHTOFIREHOSETIMEOUT:50
RESETTIMEOUT:500
RESETDELAYTIME:5
Image Search Path: C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_sp arse_images
RAWPROGRAM file path: C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_sp arse_images\rawprogram0.xml
PATCH file path:C:\Users\alimobile\Desktop\FlashOne1.9\s2_ind ia_sparse_images\patch0.xml
Programmer Path:C:\Users\alimobile\Desktop\FlashOne1.9\s2_ind ia_sparse_images\prog_emmc_firehose_8976_ddr.mbn
Start Download
Program Path:C:\Users\alimobile\Desktop\FlashOne1.9\s2_ind ia_sparse_images\prog_emmc_firehose_8976_ddr.mbn
QSAHARASERVER CALLED LIKE THIS: 'C:\Users\alimobile\Desktop\FlashOne1.9\bin\QSahar aServer.exe -p \\.\COM2 -s 13:C:\Users\alimobile\Desktop\FlashOne1.9\s2_india _sparse_images\prog_emmc_firehose_8976_ddr.mbn 'Current working dir: C:\Users\alimobile\AppData\Roaming\Qualcomm\QFIL
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_sp arse_images\prog_emmc_firehose_8976_ddr.mbn
14:29:20: Requested ID 13, file: "C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\prog_emmc_firehose_8976_ddr.mbn"
14:29:21: 349548 bytes transferred in 0.453000 seconds (0.7359MBps)
14:29:21: File transferred successfully
14:29:21: Sahara protocol completed
Switch To FireHose
Device Type:eMMC
Platform:8x26
Skip Write:False
Use Verbose:False
Binary build date: Jun 3 2015 @ 17:12:06
Build version: 15.06. 3.17.12.06
14:29:24: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS
C:\Users\alimobile\Desktop\FlashOne1.9\bin\fh_load er.exe --port=\\.\COM2 --sendxml=rawprogram0.xml --search_path=C:\Users\alimobile\Desktop\FlashOne1.9 \s2_india_sparse_images --noprompt --showpercentagecomplete --maxpayloadsizeinbytes=49152 --zlpawarehost=1 --memoryname=eMMC
14:29:24: INFO: Current working dir (cwd): C:\Users\alimobile\AppData\Roaming\Qualcomm\QFIL\
14:29:24: INFO: Showing network mappings to allow debugging
14:29:24: INFO:
14:29:24: INFO: Trying to store 'rawprogram0.xml' in string table
14:29:24: INFO: Looking for file 'rawprogram0.xml'
14:29:24: INFO: User wants to talk to port '\\.\COM2'
14:29:24: INFO: Took 0.00000000 seconds to open port
14:29:24: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power>
14:29:24: INFO: If you don't want this, use --dontsorttags
14:29:24: INFO: Looking for file 'NON-HLOS.bin'
14:29:24: INFO: Looking for file 'sbl1.mbn'
14:29:24: INFO: Looking for file 'rpm.mbn'
14:29:24: INFO: Looking for file 'tz.mbn'
14:29:24: INFO: Looking for file 'hyp.mbn'
14:29:24: INFO: Looking for file 'adspso.bin'
14:29:24: INFO: Looking for file 'oemconfig.img'
14:29:24: INFO: Looking for file 'ddr.bin'
14:29:24: INFO: Looking for file 'sec.dat'
14:29:24: INFO: Looking for file 'splash.img'
14:29:24: INFO: Looking for file 'emmc_appsboot.mbn'
14:29:24: INFO: Looking for file 'boot.img'
14:29:24: INFO: Looking for file 'recovery.img'
14:29:24: INFO: Looking for file 'system_1.img'
14:29:24: INFO: Looking for file 'system_2.img'
14:29:24: INFO: Looking for file 'system_3.img'
14:29:24: INFO: Looking for file 'system_4.img'
14:29:24: INFO: Looking for file 'system_5.img'
14:29:24: INFO: Looking for file 'system_6.img'
14:29:24: INFO: Looking for file 'system_7.img'
14:29:24: INFO: Looking for file 'system_8.img'
14:29:24: INFO: Looking for file 'system_9.img'
14:29:24: INFO: Looking for file 'system_10.img'
14:29:24: INFO: Looking for file 'system_11.img'
14:29:24: INFO: Looking for file 'system_12.img'
14:29:24: INFO: Looking for file 'system_13.img'
14:29:24: INFO: Looking for file 'system_14.img'
14:29:24: INFO: Looking for file 'system_15.img'
14:29:24: INFO: Looking for file 'system_16.img'
14:29:24: INFO: Looking for file 'system_17.img'
14:29:24: INFO: Looking for file 'system_18.img'
14:29:24: INFO: Looking for file 'system_19.img'
14:29:24: INFO: Looking for file 'system_20.img'
14:29:24: INFO: Looking for file 'system_21.img'
14:29:24: INFO: Looking for file 'system_22.img'
14:29:24: INFO: Looking for file 'system_23.img'
14:29:24: INFO: Looking for file 'system_24.img'
14:29:24: INFO: Looking for file 'system_25.img'
14:29:24: INFO: Looking for file 'system_26.img'
14:29:24: INFO: Looking for file 'system_27.img'
14:29:24: INFO: Looking for file 'system_28.img'
14:29:24: INFO: Looking for file 'system_29.img'
14:29:24: INFO: Looking for file 'system_30.img'
14:29:24: INFO: Looking for file 'system_31.img'
14:29:24: INFO: Looking for file 'system_32.img'
14:29:24: INFO: Looking for file 'system_33.img'
14:29:24: INFO: Looking for file 'system_34.img'
14:29:24: INFO: Looking for file 'system_35.img'
14:29:24: INFO: Looking for file 'system_36.img'
14:29:24: INFO: Looking for file 'system_37.img'
14:29:24: INFO: Looking for file 'system_38.img'
14:29:24: INFO: Looking for file 'system_39.img'
14:29:24: INFO: Looking for file 'system_40.img'
14:29:24: INFO: Looking for file 'system_41.img'
14:29:24: INFO: Looking for file 'system_42.img'
14:29:24: INFO: Looking for file 'system_43.img'
14:29:24: INFO: Looking for file 'system_44.img'
14:29:24: INFO: Looking for file 'system_45.img'
14:29:24: INFO: Looking for file 'system_46.img'
14:29:24: INFO: Looking for file 'system_47.img'
14:29:24: INFO: Looking for file 'system_48.img'
14:29:24: INFO: Looking for file 'system_49.img'
14:29:24: INFO: Looking for file 'system_50.img'
14:29:24: INFO: Looking for file 'system_51.img'
14:29:24: INFO: Looking for file 'system_52.img'
14:29:24: INFO: Looking for file 'system_53.img'
14:29:24: INFO: Looking for file 'system_54.img'
14:29:24: INFO: Looking for file 'system_55.img'
14:29:24: INFO: Looking for file 'system_56.img'
14:29:24: INFO: Looking for file 'system_57.img'
14:29:24: INFO: Looking for file 'system_58.img'
14:29:24: INFO: Looking for file 'system_59.img'
14:29:24: INFO: Looking for file 'system_60.img'
14:29:24: INFO: Looking for file 'system_61.img'
14:29:24: INFO: Looking for file 'system_62.img'
14:29:24: INFO: Looking for file 'system_63.img'
14:29:24: INFO: Looking for file 'cache_1.img'
14:29:24: INFO: Looking for file 'cache_2.img'
14:29:24: INFO: Looking for file 'cache_3.img'
14:29:24: INFO: Looking for file 'misc.img'
14:29:24: INFO: Looking for file 'mdtp.img'
14:29:24: INFO: Looking for file 'cmnlib.mbn'
14:29:24: INFO: Looking for file 'keymaster.mbn'
14:29:24: INFO: Looking for file 'userdata_1.img'
14:29:24: INFO: Looking for file 'userdata_2.img'
14:29:24: INFO: Looking for file 'userdata_3.img'
14:29:24: INFO: Looking for file 'userdata_4.img'
14:29:24: INFO: Looking for file 'userdata_5.img'
14:29:24: INFO: Looking for file 'userdata_6.img'
14:29:24: INFO: Looking for file 'userdata_7.img'
14:29:24: INFO: Looking for file 'userdata_8.img'
14:29:24: INFO: Looking for file 'userdata_9.img'
14:29:24: INFO: Looking for file 'userdata_10.img'
14:29:24: INFO: Looking for file 'userdata_11.img'
14:29:24: INFO: Looking for file 'userdata_12.img'
14:29:24: INFO: Looking for file 'userdata_13.img'
14:29:24: INFO: Looking for file 'userdata_14.img'
14:29:24: INFO: Looking for file 'userdata_15.img'
14:29:24: INFO: Looking for file 'userdata_16.img'
14:29:24: INFO: Looking for file 'userdata_17.img'
14:29:24: INFO: Looking for file 'userdata_18.img'
14:29:24: INFO: Looking for file 'userdata_19.img'
14:29:24: INFO: Looking for file 'userdata_20.img'
14:29:24: INFO: Looking for file 'userdata_21.img'
14:29:24: INFO: Looking for file 'userdata_22.img'
14:29:24: INFO: Looking for file 'userdata_23.img'
14:29:24: INFO: Looking for file 'userdata_24.img'
14:29:24: INFO: Looking for file 'userdata_25.img'
14:29:24: INFO: Looking for file 'userdata_26.img'
14:29:24: INFO: Looking for file 'userdata_27.img'
14:29:24: INFO: Looking for file 'userdata_28.img'
14:29:24: INFO: Looking for file 'userdata_29.img'
14:29:24: INFO: Looking for file 'userdata_30.img'
14:29:24: INFO: Looking for file 'userdata_31.img'
14:29:24: INFO: Looking for file 'userdata_32.img'
14:29:24: INFO: Looking for file 'userdata_33.img'
14:29:24: INFO: Looking for file 'userdata_34.img'
14:29:24: INFO: Looking for file 'userdata_35.img'
14:29:24: INFO: Looking for file 'userdata_36.img'
14:29:24: INFO: Looking for file 'userdata_37.img'
14:29:24: INFO: Looking for file 'userdata_38.img'
14:29:24: INFO: Looking for file 'userdata_39.img'
14:29:24: INFO: Looking for file 'userdata_40.img'
14:29:24: INFO: Looking for file 'userdata_41.img'
14:29:24: INFO: Looking for file 'userdata_42.img'
14:29:24: INFO: Looking for file 'userdata_43.img'
14:29:24: INFO: Looking for file 'userdata_44.img'
14:29:24: INFO: Looking for file 'userdata_45.img'
14:29:24: INFO: Looking for file 'userdata_46.img'
14:29:24: INFO: Looking for file 'userdata_47.img'
14:29:24: INFO: Looking for file 'userdata_48.img'
14:29:24: INFO: Looking for file 'userdata_49.img'
14:29:24: INFO: Looking for file 'userdata_50.img'
14:29:24: INFO: Looking for file 'userdata_51.img'
14:29:24: INFO: Looking for file 'userdata_52.img'
14:29:24: INFO: Looking for file 'userdata_53.img'
14:29:24: INFO: Looking for file 'userdata_54.img'
14:29:24: INFO: Looking for file 'userdata_55.img'
14:29:24: INFO: Looking for file 'userdata_56.img'
14:29:24: INFO: Looking for file 'userdata_57.img'
14:29:24: INFO: Looking for file 'userdata_58.img'
14:29:24: INFO: Looking for file 'userdata_59.img'
14:29:24: INFO: Looking for file 'userdata_60.img'
14:29:24: INFO: Looking for file 'userdata_61.img'
14:29:24: INFO: Looking for file 'userdata_62.img'
14:29:24: INFO: Looking for file 'userdata_63.img'
14:29:24: INFO: Looking for file 'userdata_64.img'
14:29:24: INFO: Looking for file 'userdata_65.img'
14:29:24: INFO: Looking for file 'userdata_66.img'
14:29:24: INFO: Looking for file 'userdata_67.img'
14:29:24: INFO: Looking for file 'userdata_68.img'
14:29:24: INFO: Looking for file 'userdata_69.img'
14:29:24: INFO: Looking for file 'userdata_70.img'
14:29:24: INFO: Looking for file 'userdata_71.img'
14:29:24: INFO: Looking for file 'userdata_72.img'
14:29:24: INFO: Looking for file 'gpt_main0.bin'
14:29:24: INFO: Looking for file 'gpt_backup0.bin'
14:29:24: INFO:
Total to be tansferd with <program> or <read> is 3.29 GB
14:29:24: INFO: Sending <configure>
14:29:24: INFO: TARGET SAID: 'logbuf@0x0806D768 fh@0x0806A5D0'
14:29:24: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 49152
14:29:24: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 1048576
14:29:24: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 1048576
14:29:24: INFO: In handleProgram('NON-HLOS.bin')
14:29:24: INFO: ================================================== =====
14:29:24: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\NON-HLOS.bin'}
14:29:24: INFO: {<program> (81.21 MB) 166317 sectors needed at location 131072 on LUN 0}
14:29:25: INFO: TARGET SAID: 'start 131072, num 166317'
14:29:27: INFO: Overall to target 2.013 seconds (18.88 MBps)
14:29:27: INFO: {percent files transferred 1.13%}
14:29:29: INFO: Overall to target 4.025 seconds (19.38 MBps)
14:29:29: INFO: {percent files transferred 2.32%}
14:29:29: INFO: Overall to target 4.244 seconds (19.14 MBps)
14:29:29: INFO: {percent files transferred 2.41%}
14:29:29: INFO: TARGET SAID: 'Finished sector address 297389'
14:29:29: INFO:
14:29:29: INFO: ================================================== =====
14:29:29: INFO: ==================== {SUCCESS} ========================
14:29:29: INFO: In handleProgram('sbl1.mbn')
14:29:29: INFO: Looking for file 'sbl1.mbn'
14:29:29: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\sbl1.mbn'}
14:29:29: INFO: {<program> (356.57 KB) 714 sectors needed at location 393234 on LUN 0}
14:29:29: INFO: TARGET SAID: 'start 393234, num 714'
14:29:29: INFO: FILE ACCESS SLOW!! 357.00 KB in 0.015 seconds ( 23.24 MBps) --- Overall to target 0.078 seconds (4.47 MBps)
14:29:29: INFO: {percent files transferred 2.42%}
14:29:29: INFO: TARGET SAID: 'Finished sector address 393948'
14:29:29: INFO:
14:29:29: INFO: {<program> (356.57 KB) 714 sectors needed at location 394258 on LUN 0}
14:29:29: INFO: TARGET SAID: 'start 394258, num 714'
14:29:29: INFO: FILE ACCESS SLOW!! 357.00 KB in 0.015 seconds ( 23.24 MBps) --- Overall to target 0.047 seconds (7.42 MBps)
14:29:29: INFO: {percent files transferred 2.43%}
14:29:29: INFO: TARGET SAID: 'Finished sector address 394972'
14:29:29: INFO:
14:29:29: INFO: In handleProgram('rpm.mbn')
14:29:29: INFO: Looking for file 'rpm.mbn'
14:29:29: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\rpm.mbn'}
14:29:29: INFO: {<program> (163.84 KB) 328 sectors needed at location 395282 on LUN 0}
14:29:30: INFO: TARGET SAID: 'start 395282, num 328'
14:29:30: INFO: FILE ACCESS SLOW!! 164.00 KB in 0.015 seconds ( 10.68 MBps) --- Overall to target 0.047 seconds (3.41 MBps)
14:29:30: INFO: {percent files transferred 2.44%}
14:29:30: INFO: TARGET SAID: 'Finished sector address 395610'
14:29:30: INFO:
14:29:30: INFO: ================================================== =====
14:29:30: INFO: ==================== {SUCCESS} ========================
14:29:30: INFO: In handleProgram('rpm.mbn')
14:29:30: INFO: Looking for file 'rpm.mbn'
14:29:30: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\rpm.mbn'}
14:29:30: INFO: {<program> (163.84 KB) 328 sectors needed at location 396306 on LUN 0}
14:29:30: INFO: TARGET SAID: 'start 396306, num 328'
14:29:30: INFO: FILE ACCESS SLOW!! 164.00 KB in 0.015 seconds ( 10.68 MBps) --- Overall to target 0.010 seconds (16.02 MBps)
14:29:30: INFO: TARGET SAID: 'Finished sector address 396634'
14:29:30: INFO:
14:29:30: INFO: In handleProgram('tz.mbn')
14:29:30: INFO: Looking for file 'tz.mbn'
14:29:30: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\tz.mbn'}
14:29:30: INFO: {<program> (633.40 KB) 1267 sectors needed at location 397330 on LUN 0}
14:29:30: INFO: TARGET SAID: 'start 397330, num 1267'
14:29:30: INFO: FILE ACCESS SLOW!! 633.50 KB in 0.015 seconds ( 41.24 MBps) --- Overall to target 0.015 seconds (41.24 MBps)
14:29:30: INFO: {percent files transferred 2.46%}
14:29:30: INFO: TARGET SAID: 'Finished sector address 398597'
14:29:30: INFO:
14:29:30: INFO: {<program> (633.40 KB) 1267 sectors needed at location 401426 on LUN 0}
14:29:30: INFO: TARGET SAID: 'start 401426, num 1267'
14:29:30: INFO: FILE ACCESS SLOW!! 633.50 KB in 0.015 seconds ( 41.24 MBps) --- Overall to target 0.031 seconds (19.96 MBps)
14:29:30: INFO: {percent files transferred 2.48%}
14:29:30: INFO: TARGET SAID: 'Finished sector address 402693'
14:29:30: INFO:
14:29:30: INFO: In handleProgram('hyp.mbn')
14:29:30: INFO: Looking for file 'hyp.mbn'
14:29:30: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\hyp.mbn'}
14:29:30: INFO: {<program> (72.00 KB) 144 sectors needed at location 405522 on LUN 0}
14:29:31: INFO: TARGET SAID: 'start 405522, num 144'
14:29:31: INFO: FILE ACCESS SLOW!! 72.00 KB in 0.015 seconds ( 4.69 MBps) --- Overall to target 0.032 seconds (2.20 MBps)
14:29:31: INFO: {percent files transferred 2.48%}
14:29:31: INFO: TARGET SAID: 'Finished sector address 405666'
14:29:31: INFO:
14:29:31: INFO: ================================================== =====
14:29:31: INFO: ==================== {SUCCESS} ========================
14:29:31: INFO: In handleProgram('hyp.mbn')
14:29:31: INFO: Looking for file 'hyp.mbn'
14:29:31: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\hyp.mbn'}
14:29:31: INFO: {<program> (72.00 KB) 144 sectors needed at location 406546 on LUN 0}
14:29:31: INFO: TARGET SAID: 'start 406546, num 144'
14:29:31: INFO: FILE ACCESS SLOW!! 72.00 KB in 0.015 seconds ( 4.69 MBps) --- Overall to target 0.010 seconds (7.03 MBps)
14:29:31: INFO: TARGET SAID: 'Finished sector address 406690'
14:29:31: INFO:
14:29:31: INFO: In handleProgram('adspso.bin')
14:29:31: INFO: Looking for file 'adspso.bin'
14:29:31: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\adspso.bin'}
14:29:31: INFO: {<program> (16.00 MB) 32768 sectors needed at location 407570 on LUN 0}
14:29:31: INFO: TARGET SAID: 'start 407570, num 32768'
14:29:32: INFO: Overall to target 0.968 seconds (16.53 MBps)
14:29:32: INFO: {percent files transferred 2.96%}
14:29:32: INFO: TARGET SAID: 'Finished sector address 440338'
14:29:32: INFO:
14:29:32: INFO: ================================================== =====
14:29:32: INFO: ==================== {SUCCESS} ========================
14:29:32: INFO: In handleProgram('oemconfig.img')
14:29:32: INFO: Looking for file 'oemconfig.img'
14:29:32: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\oemconfig.img'}
14:29:32: INFO: {<program> (1.00 KB) 2 sectors needed at location 446482 on LUN 0}
14:29:32: INFO: TARGET SAID: 'start 446482, num 2'
14:29:32: INFO: FILE ACCESS SLOW!! 1.00 KB in 0.015 seconds ( 66.67 KBps) --- Overall to target 0.016 seconds (62.50 KBps)
14:29:32: INFO: TARGET SAID: 'Finished sector address 446484'
14:29:32: INFO:
14:29:32: INFO: In handleProgram('ddr.bin')
14:29:32: INFO: Looking for file 'ddr.bin'
14:29:32: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\ddr.bin'}
14:29:32: INFO: {<program> (32.00 KB) 64 sectors needed at location 655360 on LUN 0}
14:29:32: INFO: TARGET SAID: 'start 655360, num 64'
14:29:33: INFO: FILE ACCESS SLOW!! 32.00 KB in 0.015 seconds ( 2.08 MBps) --- Overall to target 0.063 seconds (507.94 KBps)
14:29:33: INFO: {percent files transferred 2.96%}
14:29:33: INFO: TARGET SAID: 'Finished sector address 655424'
14:29:33: INFO:
14:29:33: INFO: ================================================== =====
14:29:33: INFO: ==================== {SUCCESS} ========================
14:29:33: INFO: In handleProgram('sec.dat')
14:29:33: INFO: Looking for file 'sec.dat'
14:29:33: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\sec.dat'}
14:29:33: INFO: {<program> (436.00 B) 1 sectors needed at location 658496 on LUN 0}
14:29:33: INFO: TARGET SAID: 'start 658496, num 1'
14:29:33: INFO: FILE ACCESS SLOW!! 512.00 B in 0.015 seconds ( 33.33 KBps) --- Overall to target 0.010 seconds (50.00 KBps)
14:29:33: INFO: TARGET SAID: 'Finished sector address 658497'
14:29:33: INFO:
14:29:33: INFO: In handleProgram('splash.img')
14:29:33: INFO: Looking for file 'splash.img'
14:29:33: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\splash.img'}
14:29:33: INFO: {<program> (35.60 MB) 72900 sectors needed at location 658528 on LUN 0}
14:29:33: INFO: TARGET SAID: 'start 658528, num 72900'
14:29:35: INFO: FILE ACCESS SLOW!! 29.00 MB in 0.622 seconds ( 46.62 MBps) --- Overall to target 2.028 seconds (14.30 MBps)
14:29:35: INFO: {percent files transferred 3.82%}
14:29:35: INFO: Overall to target 2.449 seconds (14.53 MBps)
14:29:35: INFO: {percent files transferred 4.01%}
14:29:36: INFO: TARGET SAID: 'Finished sector address 731428'
14:29:36: INFO:
14:29:36: INFO: ================================================== =====
14:29:36: INFO: ==================== {SUCCESS} ========================
14:29:36: INFO: {percent files transferred 4.01%}
14:29:36: INFO: In handleProgram('emmc_appsboot.mbn')
14:29:36: INFO: Looking for file 'emmc_appsboot.mbn'
14:29:36: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\emmc_appsboot.mbn'}
14:29:36: INFO: {<program> (553.48 KB) 1107 sectors needed at location 760928 on LUN 0}
14:29:36: INFO: TARGET SAID: 'start 760928, num 1107'
14:29:36: INFO: FILE ACCESS SLOW!! 553.50 KB in 0.015 seconds ( 36.04 MBps) --- Overall to target 0.109 seconds (4.96 MBps)
14:29:36: INFO: {percent files transferred 4.03%}
14:29:36: INFO: TARGET SAID: 'Finished sector address 762035'
14:29:36: INFO:
14:29:36: INFO: {<program> (553.48 KB) 1107 sectors needed at location 762976 on LUN 0}
14:29:36: INFO: TARGET SAID: 'start 762976, num 1107'
14:29:36: INFO: FILE ACCESS SLOW!! 553.50 KB in 0.015 seconds ( 36.04 MBps) --- Overall to target 0.016 seconds (33.78 MBps)
14:29:36: INFO: {percent files transferred 4.05%}
14:29:36: INFO: TARGET SAID: 'Finished sector address 764083'
14:29:36: INFO:
14:29:36: INFO: In handleProgram('boot.img')
14:29:36: INFO: Looking for file 'boot.img'
14:29:36: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\boot.img'}
14:29:36: INFO: {<program> (10.56 MB) 21635 sectors needed at location 765024 on LUN 0}
14:29:36: INFO: TARGET SAID: 'start 765024, num 21635'
14:29:37: INFO: Overall to target 0.687 seconds (15.38 MBps)
14:29:37: INFO: {percent files transferred 4.36%}
14:29:37: INFO: TARGET SAID: 'Finished sector address 786659'
14:29:37: INFO:
14:29:37: INFO: ================================================== =====
14:29:37: INFO: ==================== {SUCCESS} ========================
14:29:37: INFO: In handleProgram('recovery.img')
14:29:37: INFO: Looking for file 'recovery.img'
14:29:37: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\recovery.img'}
14:29:37: INFO: {<program> (13.57 MB) 27783 sectors needed at location 896096 on LUN 0}
14:29:37: INFO: TARGET SAID: 'start 896096, num 27783'
14:29:38: INFO: Overall to target 0.796 seconds (17.04 MBps)
14:29:38: INFO: {percent files transferred 4.76%}
14:29:38: INFO: TARGET SAID: 'Finished sector address 923879'
14:29:38: INFO:
14:29:38: INFO: ================================================== =====
14:29:38: INFO: ==================== {SUCCESS} ========================
14:29:38: INFO: In handleProgram('system_1.img')
14:29:38: INFO: Looking for file 'system_1.img'
14:29:38: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_1.img'}
14:29:38: INFO: {<program> (128.01 MB) 262160 sectors needed at location 1179648 on LUN 0}
14:29:38: INFO: TARGET SAID: 'start 1179648, num 262160'
14:29:40: INFO: FILE ACCESS SLOW!! 30.00 MB in 0.627 seconds ( 47.85 MBps) --- Overall to target 2.044 seconds (14.68 MBps)
14:29:40: INFO: {percent files transferred 5.65%}
14:29:42: INFO: Overall to target 4.072 seconds (17.19 MBps)
14:29:42: INFO: {percent files transferred 6.84%}
14:29:44: INFO: Overall to target 6.100 seconds (18.03 MBps)
14:29:44: INFO: {percent files transferred 8.03%}
14:29:45: INFO: Overall to target 7.051 seconds (18.15 MBps)
14:29:45: INFO: {percent files transferred 8.56%}
14:29:45: INFO: TARGET SAID: 'Finished sector address 1441808'
14:29:45: INFO:
14:29:45: INFO: ================================================== =====
14:29:45: INFO: ==================== {SUCCESS} ========================
14:29:45: INFO: In handleProgram('system_2.img')
14:29:45: INFO: Looking for file 'system_2.img'
14:29:45: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_2.img'}
14:29:45: INFO: {<program> (8.00 KB) 16 sectors needed at location 1443848 on LUN 0}
14:29:45: INFO: TARGET SAID: 'start 1443848, num 16'
14:29:45: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps)
14:29:46: INFO: TARGET SAID: 'Finished sector address 1443864'
14:29:46: INFO:
14:29:46: INFO: ================================================== =====
14:29:46: INFO: ==================== {SUCCESS} ========================
14:29:46: INFO: {percent files transferred 8.56%}
14:29:46: INFO: In handleProgram('system_3.img')
14:29:46: INFO: Looking for file 'system_3.img'
14:29:46: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_3.img'}
14:29:46: INFO: {<program> (125.00 MB) 256000 sectors needed at location 1447928 on LUN 0}
14:29:46: INFO: TARGET SAID: 'start 1447928, num 256000'
14:29:48: INFO: Overall to target 2.012 seconds (19.38 MBps)
14:29:48: INFO: {percent files transferred 9.72%}
14:29:50: INFO: Overall to target 4.056 seconds (19.48 MBps)
14:29:50: INFO: {percent files transferred 10.91%}
14:29:52: INFO: Overall to target 6.084 seconds (19.56 MBps)
14:29:52: INFO: {percent files transferred 12.10%}
14:29:52: INFO: Overall to target 6.427 seconds (19.45 MBps)
14:29:52: INFO: {percent files transferred 12.27%}
14:29:52: INFO: TARGET SAID: 'Finished sector address 1703928'
14:29:52: INFO:
14:29:52: INFO: ================================================== =====
14:29:52: INFO: ==================== {SUCCESS} ========================
14:29:52: INFO: In handleProgram('system_4.img')
14:29:52: INFO: Looking for file 'system_4.img'
14:29:52: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_4.img'}
14:29:52: INFO: {<program> (8.00 KB) 16 sectors needed at location 1703936 on LUN 0}
14:29:52: INFO: TARGET SAID: 'start 1703936, num 16'
14:29:52: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.032 seconds (250.00 KBps)
14:29:52: INFO: TARGET SAID: 'Finished sector address 1703952'
14:29:52: INFO:
14:29:52: INFO: In handleProgram('system_5.img')
14:29:52: INFO: Looking for file 'system_5.img'
14:29:52: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_5.img'}
14:29:52: INFO: {<program> (126.00 MB) 258056 sectors needed at location 1708016 on LUN 0}
14:29:53: INFO: TARGET SAID: 'start 1708016, num 258056'
14:29:55: INFO: Overall to target 2.059 seconds (19.43 MBps)
14:29:55: INFO: {percent files transferred 13.46%}
14:29:57: INFO: Overall to target 4.071 seconds (19.65 MBps)
14:29:57: INFO: {percent files transferred 14.65%}
14:29:59: INFO: Overall to target 6.099 seconds (19.68 MBps)
14:29:59: INFO: {percent files transferred 15.84%}
14:29:59: INFO: Overall to target 6.458 seconds (19.51 MBps)
14:29:59: INFO: {percent files transferred 16.02%}
14:29:59: INFO: TARGET SAID: 'Finished sector address 1966072'
14:29:59: INFO:
14:29:59: INFO: ================================================== =====
14:29:59: INFO: ==================== {SUCCESS} ========================
14:29:59: INFO: In handleProgram('system_6.img')
14:29:59: INFO: Looking for file 'system_6.img'
14:29:59: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_6.img'}
14:29:59: INFO: {<program> (8.00 KB) 16 sectors needed at location 1966080 on LUN 0}
14:29:59: INFO: TARGET SAID: 'start 1966080, num 16'
14:29:59: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps)
14:29:59: INFO: TARGET SAID: 'Finished sector address 1966096'
14:29:59: INFO:
14:29:59: INFO: In handleProgram('system_7.img')
14:29:59: INFO: Looking for file 'system_7.img'
14:29:59: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_7.img'}
14:29:59: INFO: {<program> (8.00 KB) 16 sectors needed at location 1968136 on LUN 0}
14:29:59: INFO: TARGET SAID: 'start 1968136, num 16'
14:29:59: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps)
14:30:00: INFO: TARGET SAID: 'Finished sector address 1968152'
14:30:00: INFO:
14:30:00: INFO: ================================================== =====
14:30:00: INFO: ==================== {SUCCESS} ========================
14:30:00: INFO: {percent files transferred 16.02%}
14:30:00: INFO: In handleProgram('system_8.img')
14:30:00: INFO: Looking for file 'system_8.img'
14:30:00: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_8.img'}
14:30:00: INFO: {<program> (125.00 MB) 256000 sectors needed at location 1972216 on LUN 0}
14:30:00: INFO: TARGET SAID: 'start 1972216, num 256000'
14:30:02: INFO: Overall to target 2.012 seconds (19.88 MBps)
14:30:02: INFO: {percent files transferred 17.20%}
14:30:04: INFO: Overall to target 4.056 seconds (19.97 MBps)
14:30:04: INFO: {percent files transferred 18.42%}
14:30:06: INFO: Overall to target 6.068 seconds (19.94 MBps)
14:30:06: INFO: {percent files transferred 19.61%}
14:30:06: INFO: Overall to target 6.287 seconds (19.88 MBps)
14:30:06: INFO: {percent files transferred 19.73%}
14:30:06: INFO: TARGET SAID: 'Finished sector address 2228216'
14:30:06: INFO:
14:30:06: INFO: ================================================== =====
14:30:06: INFO: ==================== {SUCCESS} ========================
14:30:06: INFO: In handleProgram('system_9.img')
14:30:06: INFO: Looking for file 'system_9.img'
14:30:06: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_9.img'}
14:30:06: INFO: {<program> (8.00 KB) 16 sectors needed at location 2228224 on LUN 0}
14:30:06: INFO: TARGET SAID: 'start 2228224, num 16'
14:30:06: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps)
14:30:06: INFO: TARGET SAID: 'Finished sector address 2228240'
14:30:06: INFO:
14:30:06: INFO: In handleProgram('system_10.img')
14:30:06: INFO: Looking for file 'system_10.img'
14:30:06: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_10.img'}
14:30:06: INFO: {<program> (126.00 MB) 258056 sectors needed at location 2232304 on LUN 0}
14:30:06: INFO: TARGET SAID: 'start 2232304, num 258056'
14:30:08: INFO: Overall to target 2.044 seconds (19.57 MBps)
14:30:08: INFO: {percent files transferred 20.91%}
14:30:11: INFO: Overall to target 4.103 seconds (19.74 MBps)
14:30:11: INFO: {percent files transferred 22.13%}
14:30:13: INFO: Overall to target 6.131 seconds (19.74 MBps)
14:30:13: INFO: {percent files transferred 23.32%}
14:30:13: INFO: Overall to target 6.427 seconds (19.61 MBps)
14:30:13: INFO: {percent files transferred 23.47%}
14:30:13: INFO: TARGET SAID: 'Finished sector address 2490360'
14:30:13: INFO:
14:30:13: INFO: ================================================== =====
14:30:13: INFO: ==================== {SUCCESS} ========================
14:30:13: INFO: In handleProgram('system_11.img')
14:30:13: INFO: Looking for file 'system_11.img'
14:30:13: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_11.img'}
14:30:13: INFO: {<program> (8.00 KB) 16 sectors needed at location 2490368 on LUN 0}
14:30:13: INFO: TARGET SAID: 'start 2490368, num 16'
14:30:13: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps)
14:30:13: INFO: TARGET SAID: 'Finished sector address 2490384'
14:30:13: INFO:
14:30:13: INFO: In handleProgram('system_12.img')
14:30:13: INFO: Looking for file 'system_12.img'
14:30:13: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_12.img'}
14:30:13: INFO: {<program> (8.00 KB) 16 sectors needed at location 2492424 on LUN 0}
14:30:13: INFO: TARGET SAID: 'start 2492424, num 16'
14:30:13: INFO: TARGET SAID: 'Finished sector address 2492440'
14:30:13: INFO:
14:30:13: INFO: In handleProgram('system_13.img')
14:30:13: INFO: Looking for file 'system_13.img'
14:30:13: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_13.img'}
14:30:13: INFO: {<program> (125.00 MB) 256000 sectors needed at location 2496504 on LUN 0}
14:30:14: INFO: TARGET SAID: 'start 2496504, num 256000'
14:30:16: INFO: Overall to target 2.059 seconds (19.43 MBps)
14:30:16: INFO: {percent files transferred 24.66%}
14:30:18: INFO: Overall to target 4.103 seconds (19.01 MBps)
14:30:18: INFO: {percent files transferred 25.78%}
14:30:20: INFO: Overall to target 6.131 seconds (19.25 MBps)
14:30:20: INFO: {percent files transferred 26.97%}
14:30:20: INFO: Overall to target 6.537 seconds (19.12 MBps)
14:30:20: INFO: {percent files transferred 27.18%}
14:30:20: INFO: TARGET SAID: 'Finished sector address 2752504'
14:30:20: INFO:
14:30:20: INFO: ================================================== =====
14:30:20: INFO: ==================== {SUCCESS} ========================
14:30:20: INFO: In handleProgram('system_14.img')
14:30:20: INFO: Looking for file 'system_14.img'
14:30:20: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_14.img'}
14:30:20: INFO: {<program> (8.00 KB) 16 sectors needed at location 2752512 on LUN 0}
14:30:20: INFO: TARGET SAID: 'start 2752512, num 16'
14:30:20: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.047 seconds (170.21 KBps)
14:30:20: INFO: TARGET SAID: 'Finished sector address 2752528'
14:30:20: INFO:
14:30:20: INFO: In handleProgram('system_15.img')
14:30:20: INFO: Looking for file 'system_15.img'
14:30:20: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_15.img'}
14:30:20: INFO: {<program> (126.00 MB) 258056 sectors needed at location 2756592 on LUN 0}
14:30:21: INFO: TARGET SAID: 'start 2756592, num 258056'
14:30:23: INFO: Overall to target 2.013 seconds (19.37 MBps)
14:30:23: INFO: {percent files transferred 28.34%}
14:30:25: INFO: Overall to target 4.025 seconds (19.63 MBps)
14:30:25: INFO: {percent files transferred 29.53%}
14:30:27: INFO: Overall to target 6.053 seconds (19.66 MBps)
14:30:27: INFO: {percent files transferred 30.71%}
14:30:27: INFO: Overall to target 6.443 seconds (19.56 MBps)
14:30:27: INFO: {percent files transferred 30.92%}
14:30:27: INFO: TARGET SAID: 'Finished sector address 3014648'
14:30:27: INFO:
14:30:27: INFO: ================================================== =====
14:30:27: INFO: ==================== {SUCCESS} ========================
14:30:27: INFO: In handleProgram('system_16.img')
14:30:27: INFO: Looking for file 'system_16.img'
14:30:27: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_16.img'}
14:30:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 3014656 on LUN 0}
14:30:27: INFO: TARGET SAID: 'start 3014656, num 16'
14:30:27: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps)
14:30:27: INFO: TARGET SAID: 'Finished sector address 3014672'
14:30:27: INFO:
14:30:27: INFO: In handleProgram('system_17.img')
14:30:27: INFO: Looking for file 'system_17.img'
14:30:27: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_17.img'}
14:30:27: INFO: {<program> (8.00 KB) 16 sectors needed at location 3016712 on LUN 0}
14:30:27: INFO: TARGET SAID: 'start 3016712, num 16'
14:30:28: INFO: TARGET SAID: 'Finished sector address 3016728'
14:30:28: INFO:
14:30:28: INFO: ================================================== =====
14:30:28: INFO: ==================== {SUCCESS} ========================
14:30:28: INFO: {percent files transferred 30.92%}
14:30:28: INFO: In handleProgram('system_18.img')
14:30:28: INFO: Looking for file 'system_18.img'
14:30:28: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_18.img'}
14:30:28: INFO: {<program> (125.00 MB) 256000 sectors needed at location 3020792 on LUN 0}
14:30:28: INFO: TARGET SAID: 'start 3020792, num 256000'
14:30:30: INFO: Overall to target 2.013 seconds (19.37 MBps)
14:30:30: INFO: {percent files transferred 32.08%}
14:30:32: INFO: Overall to target 4.056 seconds (19.48 MBps)
14:30:32: INFO: {percent files transferred 33.27%}
14:30:34: INFO: Overall to target 6.084 seconds (19.56 MBps)
14:30:34: INFO: {percent files transferred 34.45%}
14:30:34: INFO: Overall to target 6.443 seconds (19.40 MBps)
14:30:34: INFO: {percent files transferred 34.63%}
14:30:34: INFO: TARGET SAID: 'Finished sector address 3276792'
14:30:34: INFO:
14:30:34: INFO: ================================================== =====
14:30:34: INFO: ==================== {SUCCESS} ========================
14:30:34: INFO: In handleProgram('system_19.img')
14:30:34: INFO: Looking for file 'system_19.img'
14:30:34: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_19.img'}
14:30:34: INFO: {<program> (8.00 KB) 16 sectors needed at location 3276800 on LUN 0}
14:30:34: INFO: TARGET SAID: 'start 3276800, num 16'
14:30:34: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps)
14:30:34: INFO: TARGET SAID: 'Finished sector address 3276816'
14:30:34: INFO:
14:30:34: INFO: In handleProgram('system_20.img')
14:30:34: INFO: Looking for file 'system_20.img'
14:30:34: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_20.img'}
14:30:34: INFO: {<program> (126.00 MB) 258056 sectors needed at location 3280880 on LUN 0}
14:30:35: INFO: TARGET SAID: 'start 3280880, num 258056'
14:30:37: INFO: Overall to target 2.059 seconds (19.43 MBps)
14:30:37: INFO: {percent files transferred 35.82%}
14:30:39: INFO: Overall to target 4.087 seconds (19.57 MBps)
14:30:39: INFO: {percent files transferred 37.01%}
14:30:41: INFO: Overall to target 6.130 seconds (19.58 MBps)
14:30:41: INFO: {percent files transferred 38.19%}
14:30:41: INFO: Overall to target 6.489 seconds (19.42 MBps)
14:30:41: INFO: {percent files transferred 38.37%}
14:30:41: INFO: TARGET SAID: 'Finished sector address 3538936'
14:30:41: INFO:
14:30:41: INFO: ================================================== =====
14:30:41: INFO: ==================== {SUCCESS} ========================
14:30:41: INFO: In handleProgram('system_21.img')
14:30:41: INFO: Looking for file 'system_21.img'
14:30:41: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_21.img'}
14:30:41: INFO: {<program> (8.00 KB) 16 sectors needed at location 3538944 on LUN 0}
14:30:41: INFO: TARGET SAID: 'start 3538944, num 16'
14:30:41: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.010 seconds (800.00 KBps)
14:30:41: INFO: TARGET SAID: 'Finished sector address 3538960'
14:30:41: INFO:
14:30:41: INFO: In handleProgram('system_22.img')
14:30:41: INFO: Looking for file 'system_22.img'
14:30:41: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_22.img'}
14:30:41: INFO: {<program> (8.00 KB) 16 sectors needed at location 3541000 on LUN 0}
14:30:41: INFO: TARGET SAID: 'start 3541000, num 16'
14:30:42: INFO: TARGET SAID: 'Finished sector address 3541016'
14:30:42: INFO:
14:30:42: INFO: ================================================== =====
14:30:42: INFO: ==================== {SUCCESS} ========================
14:30:42: INFO: {percent files transferred 38.37%}
14:30:42: INFO: In handleProgram('system_23.img')
14:30:42: INFO: Looking for file 'system_23.img'
14:30:42: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_23.img'}
14:30:42: INFO: {<program> (125.00 MB) 256000 sectors needed at location 3545080 on LUN 0}
14:30:42: INFO: TARGET SAID: 'start 3545080, num 256000'
14:30:44: INFO: Overall to target 2.044 seconds (19.57 MBps)
14:30:44: INFO: {percent files transferred 39.56%}
14:30:46: INFO: Overall to target 4.088 seconds (19.57 MBps)
14:30:46: INFO: {percent files transferred 40.75%}
14:30:48: INFO: Overall to target 6.131 seconds (19.57 MBps)
14:30:48: INFO: {percent files transferred 41.94%}
14:30:48: INFO: Overall to target 6.443 seconds (19.40 MBps)
14:30:48: INFO: {percent files transferred 42.08%}
14:30:48: INFO: TARGET SAID: 'Finished sector address 3801080'
14:30:48: INFO:
14:30:48: INFO: ================================================== =====
14:30:48: INFO: ==================== {SUCCESS} ========================
14:30:48: INFO: In handleProgram('system_24.img')
14:30:48: INFO: Looking for file 'system_24.img'
14:30:48: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_24.img'}
14:30:48: INFO: {<program> (8.00 KB) 16 sectors needed at location 3801088 on LUN 0}
14:30:48: INFO: TARGET SAID: 'start 3801088, num 16'
14:30:48: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps)
14:30:48: INFO: TARGET SAID: 'Finished sector address 3801104'
14:30:48: INFO:
14:30:48: INFO: In handleProgram('system_25.img')
14:30:48: INFO: Looking for file 'system_25.img'
14:30:48: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_25.img'}
14:30:48: INFO: {<program> (126.00 MB) 258056 sectors needed at location 3805168 on LUN 0}
14:30:49: INFO: TARGET SAID: 'start 3805168, num 258056'
14:30:51: INFO: Overall to target 2.012 seconds (19.38 MBps)
14:30:51: INFO: {percent files transferred 43.24%}
14:30:53: INFO: Overall to target 4.056 seconds (19.48 MBps)
14:30:53: INFO: {percent files transferred 44.43%}
14:30:55: INFO: Overall to target 6.099 seconds (19.51 MBps)
14:30:55: INFO: {percent files transferred 45.62%}
14:30:55: INFO: Overall to target 6.520 seconds (19.33 MBps)
14:30:55: INFO: {percent files transferred 45.83%}
14:30:55: INFO: TARGET SAID: 'Finished sector address 4063224'
14:30:55: INFO:
14:30:55: INFO: ================================================== =====
14:30:55: INFO: ==================== {SUCCESS} ========================
14:30:55: INFO: In handleProgram('system_26.img')
14:30:55: INFO: Looking for file 'system_26.img'
14:30:55: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_26.img'}
14:30:55: INFO: {<program> (8.00 KB) 16 sectors needed at location 4063232 on LUN 0}
14:30:55: INFO: TARGET SAID: 'start 4063232, num 16'
14:30:55: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.015 seconds (533.33 KBps)
14:30:55: INFO: TARGET SAID: 'Finished sector address 4063248'
14:30:55: INFO:
14:30:55: INFO: In handleProgram('system_27.img')
14:30:55: INFO: Looking for file 'system_27.img'
14:30:55: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_27.img'}
14:30:55: INFO: {<program> (126.00 MB) 258056 sectors needed at location 4067312 on LUN 0}
14:30:56: INFO: TARGET SAID: 'start 4067312, num 258056'
14:30:58: INFO: Overall to target 2.043 seconds (19.58 MBps)
14:30:58: INFO: {percent files transferred 47.01%}
14:31:00: INFO: Overall to target 4.087 seconds (19.57 MBps)
14:31:00: INFO: {percent files transferred 48.20%}
14:31:02: INFO: Overall to target 6.115 seconds (19.62 MBps)
14:31:02: INFO: {percent files transferred 49.39%}
14:31:02: INFO: Overall to target 6.489 seconds (19.42 MBps)
14:31:02: INFO: {percent files transferred 49.57%}
14:31:02: INFO: TARGET SAID: 'Finished sector address 4325368'
14:31:02: INFO:
14:31:02: INFO: ================================================== =====
14:31:02: INFO: ==================== {SUCCESS} ========================
14:31:02: INFO: In handleProgram('system_28.img')
14:31:02: INFO: Looking for file 'system_28.img'
14:31:02: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_28.img'}
14:31:02: INFO: {<program> (8.00 KB) 16 sectors needed at location 4325376 on LUN 0}
14:31:02: INFO: TARGET SAID: 'start 4325376, num 16'
14:31:02: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.031 seconds (258.06 KBps)
14:31:02: INFO: TARGET SAID: 'Finished sector address 4325392'
14:31:02: INFO:
14:31:02: INFO: In handleProgram('system_29.img')
14:31:02: INFO: Looking for file 'system_29.img'
14:31:02: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_29.img'}
14:31:02: INFO: {<program> (126.00 MB) 258056 sectors needed at location 4329456 on LUN 0}
14:31:03: INFO: TARGET SAID: 'start 4329456, num 258056'
14:31:05: INFO: Overall to target 2.044 seconds (19.57 MBps)
14:31:05: INFO: {percent files transferred 50.75%}
14:31:07: INFO: Overall to target 4.088 seconds (19.57 MBps)
14:31:07: INFO: {percent files transferred 51.94%}
14:31:09: INFO: Overall to target 6.116 seconds (19.62 MBps)
14:31:09: INFO: {percent files transferred 53.13%}
14:31:09: INFO: Overall to target 6.475 seconds (19.46 MBps)
14:31:09: INFO: {percent files transferred 53.31%}
14:31:09: INFO: TARGET SAID: 'Finished sector address 4587512'
14:31:09: INFO:
14:31:09: INFO: ================================================== =====
14:31:09: INFO: ==================== {SUCCESS} ========================
14:31:09: INFO: In handleProgram('system_30.img')
14:31:09: INFO: Looking for file 'system_30.img'
14:31:09: INFO: {<program> FILE: 'C:\Users\alimobile\Desktop\FlashOne1.9\s2_india_s parse_images\system_30.img'}
14:31:09: INFO: {<program> (8.00 KB) 16 sectors needed at location 4587520 on LUN 0}
14:31:09: INFO: TARGET SAID: 'start 4587520, num 16'
14:31:09: INFO: FILE ACCESS SLOW!! 8.00 KB in 0.015 seconds ( 533.33 KBps) --- Overall to target 0.016 seconds (500.00 KBps)
14:31:09: INFO: TARGET SAID: 'Finished sector address 4587536'
14:31:09: INFO:
14:31:09: INFO: In handleProgram('system_31.img')
Old 09-11-2018, 10:47   #13 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
just one problam data connection not working
Page generated in 0.52347 seconds with 9 queries
