11-21-2009, 09:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | Ag dead after restore flash module v2.95 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26__nand_fullflash_20091120-183246.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only rom info protocol ver: 04 ver. sw 1: HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN ver. sw 2: 28.06A.06.36.950.VA.8.26, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:5944:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 07 loader: 3.0840.00.00 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... warning: probably flash chip completely erased, no header found nfi area detection finished: failed detecting bootloader structure (source file)... source data: page only rom info protocol ver: 04 ver. sw 1: HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN ver. sw 2: 28.06A.06.36.950.VA.8.26, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.95, database date: 20.10.2009): HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished startup code area #1 check... startup code area #1 fixed Identification Done Write ... 00006000 bytes sent write core area 1 of 2... error: code: A500000BF1 error: code: 5A error: code: A50500 error: code: error: block/offset: 00000050/00050000 error: can't write nand core Write Fail Finished, time used: 222 sec Remove/Install battery now ! M now this phone is dead no power and i need a flash file to revive it it cannt fomat |
11-22-2009, 07:12 | #3 (permalink) |
Member: 430612 Status: Offline Thanks Meter: 301 | COM6 [VCP1] selected module v3.00 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:5944:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 07 loader: 3.0840.00.00 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... source data: page only rom info protocol ver: 04 ver. sw 1: HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN ver. sw 2: 28.06A.06.36.950.VA.8.26, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 warning: id-page1 area is invalid nfi area detection finished: failed warning: can not detect chip parameters, default values assigned error: can't detect ffs/eeprom address Identification Fail Finished, time used: 90 sec Remove/Install battery now ! it the same |
11-22-2009, 08:03 | #4 (permalink) |
Member: 430612 Status: Offline Thanks Meter: 301 | COM6 [VCP1] selected module v3.00 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:5944:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 07 loader: 3.0840.00.00 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done load emi configuration... apply emi configuration... ram size: 02000000 emi configuration done NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure (chip)... source data: page only rom info protocol ver: 04 ver. sw 1: HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN ver. sw 2: 28.06A.06.36.950.VA.8.26, 00000000 address offset: 00000000 ffs offset/size: 02000000/06000000 nfi area detection finished: Ok rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.3.00, database date: 20.11.2009): HEDY28_06A_PCB04_GPRS_MT6228_S02.28_06A_06_36_950_ VA_8_26.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished Identification Done Write ... formatting... .........error: code: 8A00006900 ...............................error: code: 6600006900 .................................................. ..........error: code: A502000000 error: code: 0600000000 Write Fail Finished, time used: 104 sec Remove/Install battery now ! when you fomat this what i get |
SPREADTRUM SC6600R dead after restore itself backup | paullovinicius | SpiderMan | 8 | 04-11-2010 12:20 |
N73 dead after restor backup rpl !!!!??? | 1NOKIA1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 08-30-2009 15:06 |
v3x dead after restore wrong boot ver. | waleedqwert | MSS Box II | 2 | 11-11-2008 03:08 |
N-73 Dead After Restore Backup | kalpeshoza | J.A.F. V-SPEC | 3 | 02-08-2008 04:58 |
A835 dead after restoring flash back up | chinex14 | Smart-Clip | 6 | 09-03-2005 16:14 |
