Old 04-09-2017, 12:26   #1 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
need help y336-u02 (check download state,...)
Operation : Flash [ v1.24 ]
======= Flash
Files set for flashing :
[ MCU ] : Y336-U02 V100R001C567B113.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : Y336-U02 V100R001C567B113
File : Infinity_fdl1.bin
File : Infinity_fdl2.bin
File : nvitem_w.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : sc7731g_CP0_modem.bin
File : wdsp.bin
File : logo_480x800.bin
File : fblogo_480x800.bin
File : boot.img
File : system.img
File : cache.img
File : recovery.img
File : userdata.img
File : u-boot.bin
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 80 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x16 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : sc7731g_CP0_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : wdsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo_480x800.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fblogo_480x800.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:07:53
Reconnect Power/Cable!
after successful flashing
Old 04-09-2017, 12:52   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. There has been explained - secure phones almost not supported for FW read procedure, because of this. Flash factory signed FW.
Old 04-09-2017, 13:00   #3 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
problem solve .. flash by SPD Upgrade Tool same file (which was read by cm2spd )
Old 04-14-2018, 18:41   #4 (permalink)
telmagdy's Avatar
Member: 1494964
Sonork: 100.100.573
Thanks Meter: 169
y336-u02
check download state last download maybe not completed
( ic flash )
Old 04-15-2018, 15:34   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
If you test flash ic status via spd tool you will get msg flash ic damage .. are you done with original tool?
The Following User Says Thank You to Mr.3. For This Useful Post:
Page generated in 0.17119 seconds with 10 queries
