Old 03-31-2009, 07:21   #1 (permalink)
Member: 977491
Again unlock J132 with INFINITY BOX
hello friends see this new set J132 unlock by infinity box 8th time.
COM6 [VCP1] selected
module v1.30
Device: Sony-Ericsson-J132
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 2088C0FFFFFFFF:2088C000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
Check hardware done
Read data ...
reading Sony-Ericsson-J132_eeprom_calibration-1...
file saved: C:\Documents and Settings\Administrator\Desktop\Sony-Ericsson-J132_eeprom_calibration-1_20090331-034243.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 92 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to themobileshop For This Useful Post:
Old 03-31-2009, 15:04   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 04-01-2009, 14:32   #3 (permalink)
Member: 282355
unlock J132
Today I can't unlock sony j132
COM7 [VCP0] selected
module v1.32
Action: read full flash
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
error: operation failed
Finished, time used: 50 sec
Old 04-01-2009, 14:57   #4 (permalink)
vodafoneserver's Avatar
Member: 617174
J132 cable pin out plz..................
Old 04-01-2009, 20:37   #5 (permalink)
best_s_gsm's Avatar
Member: 240499
J132 pinout is in infinity sofware
Old 04-02-2009, 10:23   #6 (permalink)
Member: 176377
j132 problem
module v1.32
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Old 04-04-2009, 12:56   #7 (permalink)
byteforce's Avatar
Member: 21296
Sonork: 100.1575170
No chance for me. I try everything that you suggest. New security and new security. I don't believe that your method works at all...
COM1 [Serial0] selected
module v1.32
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Finished, time used: 14 sec
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Old 04-05-2009, 13:23   #8 (permalink)
Member: 977491
here the pinout of this cabel. but i told that work only ipmart orignal cabel.
THANKS for using the best device INFINITY BOX.
mtariq1998@live.com
=== flash/unlock cable ===
keyboard top
_____
/12345\
_______
1: Gnd
3: box Rx/phone Tx (RJ45 pin-3)
4: box Tx/phone Rx (RJ45 pin-2)
=== USB cable ===
use ordinary Moto C350 usb cable
Old 04-05-2009, 13:27   #9 (permalink)
Member: 977491
i think any body could not undersatand this slution. bro,s i told already that in prosses when u reach on
finilizing u must re-prees power button. cheeq this now
dont forget say thanks to me.
Old 04-09-2009, 08:37   #10 (permalink)
Member: 745190
Sonork: salmanafzal
Dear Help me i am realy worried about unlock of J132 its giving error any solution please describe
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
warning: wrong data size at 0x067F0000, retry...
warning: wrong cs at 0x067F0000, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
aborted by user
Finished, time used: 80 sec
==== log: [4/8/2009 6:29:33 PM] ====
COM3 [VCP0] selected
module v1.30
Action: unlock
Boot ...
Boot fail
Finished, time used: 28 sec
Old 04-09-2009, 18:41   #11 (permalink)
Member: 130995
Hello,
You need to double check your cable, charge battery and try again. In most cases this kind of communication problems is a result of bad cable.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 04-11-2009, 04:56   #12 (permalink)
Member: 745190
Sonork: salmanafzal
thanks support team its realy cable fault
Old 04-11-2009, 08:38   #13 (permalink)
randr's Avatar
Member: 73323
module v1.32
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Finished, time used: 47 sec
Old 04-12-2009, 05:48   #14 (permalink)
Member: 745190
Sonork: salmanafzal
dear just keep press power button when finalize
The Following User Says Thank You to salmanafzal For This Useful Post:
Old 07-09-2009, 05:28   #15 (permalink)
srkhan's Avatar
Member: 153695
Sonork: 01713115300
module v1.32
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
You must set Baurdrate to very Low (11500)
How to Unlock VODAFONE225 With Infinity Box??? KUBAT1 Infinity-Box 2 01-19-2008 15:25
When we can unlock W375 with Infinity-Box? stylius Infinity-Box 1 05-14-2007 09:03
plz is c117 unlock posible with infinity box ARAB GSM Infinity-Box 2 10-20-2006 07:49
can i unlock p341 with Infinity-Box elsokary Infinity-Box 2 08-27-2005 17:45
i Can't Unlock G51E with Infinity Box flechazo Infinity-Box 1 07-09-2005 14:47
Page generated in 0.39510 seconds with 11 queries
