Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2010 Location: Tirunelveli, Tamil nadu, India
Member: 1323194 Status: Offline Thanks: 263
| Airtel FGD8900 unlock Need to unlock airtel fgd8900 I am using dragon as pin finder for infinity box, but cant connect to mobile Here is the log COM5 [ProlificSerial2] selected module v4.28 Action: read unlock codes unlock method: read codes Model: Airtel-Cordless-FGD8900 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not activate META mode error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! Someone help me. also tried with c2500 cable. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: infinity-box
Member: 1043909 Status: Offline Thanks: 8,922
| Hello, If phone can not be detected by software at all - in most cases it's a cable problem. Also, try to check phone bottom connector, it may be damaged or dirty. |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Chandigarh,India Age: 29
Member: 220603 Status: Offline Sonork: 100.1624258 Thanks: 284
| bro use standard unlock fast method this phone based on mtk6205 which is unable to enter meta mode |
| | #6 (permalink) | |
| Quote:
Here is the log COM5 [ProlificSerial2] selected module v4.28 Device: Airtel-Cordless-FGD8900 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E220A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E220A2201:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ...... required data found flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: area 1 (pass 1) required data found flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: area 1 (pass 2) .......... area 1 patch applied Ok Special operation Done ====> Write ... flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: lock-area-1 flash: 01227E220A2201:18E59F00000000 flash: 01227E220A2201:18E59F00000000 Write: lock-area-2 Write Done ====> Finalization ... Finalization Done Finished, time used: 27 sec Remove/Install battery now ! Infinity box rocks | |
| The Following User Says Thank You to Vijay dts For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:06 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
