03-02-2010, 17:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Ajanta a1900 limited service?????? Please help |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
03-02-2010, 17:46 | #2 (permalink) |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | 1) in infinity select model as BSNL G200CF & write ok imei 100% slove limited service problem see the log ------------- COM12 [Serial0] selected module v1.76 Device: Digibee-BSNL-G200CF Checking data, wait... Action: "repair imei" new imei: 3508353068***** Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100302-220934.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100302-220936.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100302-220943.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_imei-area_20100302-221002.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20100302-221016.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found imei found #2 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 1 min 46 sec Remove/Install battery now ! Finished thanks infinity |
The Following 4 Users Say Thank You to omkarvitekar For This Useful Post: |
04-01-2010, 09:33 | #3 (permalink) |
Junior Member Join Date: Mar 2010 Location: in The complete Age: 34
Member: 1266418 Status: Offline Thanks Meter: 1 | more easy use pinfinder and cpu type infenion than search with comprot and connect with infinity pana 01 module with bsnl gf2000 and write imei or flash all works wbr complete mobile lab and devloper |
Ajanta A1900 Insert sim before Repair IMEI | rajkamal_kasdol | Infinity-Box | 5 | 05-21-2010 07:47 |
Ajanta A1900 Insert sim before Repair IMEI | rajkamal_kasdol | Infinity-Box | 2 | 03-09-2010 06:16 |
ajanta a1900 pinout here | sonumobilewala | Infinity-Box | 1 | 03-04-2010 12:14 |
Need Ajanta A1900 Pinout | ..::ARUN::.. | Infinity-Box | 15 | 12-20-2009 12:10 |
Ajanta A1900,A2100,A3000,A5000 flasher | Vijendra Saini | Various | 9 | 12-16-2009 11:58 |
