07-01-2010, 07:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Alcatel 103 dead after flashing! I tried to flash alcatel OT-103 with the files from support area and now the phone doesn't power-on? and it even doesn't connect to other boxes to repair it as well! so pls inform wht is the problem and gve us the solution for this! see log below; COM9 [VCP0] selected module v3.46 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware 103X-2BRGTE1-163_XM16CA11_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_2009-06-03_En_Fr_Es_Pt_It_Orange.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4E35:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 17M provider: 103X-2BALEU1 customization: CM17AA42 customization: XM17AA42 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201006 30-155544.B0X.bin Area: Firmware flash: 8C22F60000000D:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM16CA11 customization name adjusted customization: CM16CA11 customization name adjusted customization detected: CM16CA11 customization: CM16CA11 flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201006 30-155857.B0X.bin Finished, time used: 3 min 56 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! 2ND FILE FLASHING COM9 [VCP0] selected module v3.46 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 103X-2DRGTE5-17H_XM17CB40_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-10-16_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:4E35:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN project-id: MAUI.08A.W08.36.SP1.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 163 provider: 103X-2BRGTE1 customization: CM16CA11 customization: XM16CA11 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20100701-102020.B0X.bin Area: Firmware flash: 8C22F60000000D:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CM17CB40 customization name adjusted customization: CM17CB40 customization name adjusted customization detected: CM17CB40 customization: CM17CB40 flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B698 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20100701-102344.B0X.bin Finished, time used: 4 min 8 sec Remove/Install battery now ! and i flashed another 203 with the file from support & the phone got locked! does support area have unlock/unbranded files? for these models? WBR ReyTech. |
07-01-2010, 13:56 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | 103: try to flash phone with latest firmware from support area (select it by date). If phone can not power-on after flashing (do not forget to check battery voltage, as peer my experience at least 80% of power-on problems is a problem with empty battery) you can make "Repair security area" operation. Also, do you have original full flash backup ? 203: just make unlock via "sp-unlock" button from software "Service" page. |
07-01-2010, 13:56 | #3 (permalink) |
07-01-2010, 15:48 | #4 (permalink) | |
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
WBR Reytech. | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
