02-05-2010, 21:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 218901 Status: Offline Thanks Meter: 64 | Alcatel 203a Unlocking Problem. COM4 [VCP0] selected module v3.09 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 203A-2CTLCO3-37E_XM37NM31_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MA UI_08A_W08_36_SP1_V28_F1_2009-09-01_Movistar-Colombia_En_Fr_Es_It_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:621F:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37E provider: 203A-2CTLCO3 customization: CM37NM31 customization: XM37NM31 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01187900155970 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100205-155109.B0X.bin Area: Firmware flash: 01227E221A2201:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected relocation table detected name table detected customization detected: CM37NM31 customization: CM37NM31 flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100205-155225.B0X.bin Finished, time used: 1 min 58 sec Remove/Install battery now ! unlock log: COM4 [VCP0] selected module v3.09 Device: Alcatel-203X, 203A, 203E Checking data, wait... advanced flash detection enabled Action: rebuild security area enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:621F:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 37E provider: 203A-2CTLCO3 customization: CM37NM31 customization: XM37NM31 TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM37NM31 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01187900155970 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100205-155556.B0X.bin Finished, time used: 1 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-06-2010, 04:04 | #3 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Colombia
Member: 726741 Status: Offline Thanks Meter: 1,256 | Quote:
infinity box support all versions of ot203a .... have to think a little more xD Br | |
02-07-2010, 19:23 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | So, you mean you can direct unlock without change imei as v570, without write eeprom into phone, without any kind of trick. Jejejeej I remember I unlock many bird that were not suppored by infinity and later I sent flash and info for add to support. Then you are vest than infinity coders. |
02-07-2010, 19:28 | #10 (permalink) |
Member: 416710 Status: Offline Thanks Meter: 391 | Also you can answer me why they requestphone here http://forum.gsmhosting.com/vbb/show...51&postcount=6 My opinion is if you can't help others, so don't post and continue doing for your own. Don't post only for introduce you as smart guy. |
ALCATEL C550x unlock probleme | fouad189 | FuriousGold | 10 | 09-22-2007 06:43 |
Alcatel 512 Unlock Problem | toukour | SonyEricsson (USB-Smart) | 0 | 11-29-2005 06:16 |
Alcatel 512 unlock problem | usernome | SonyEricsson (USB-Smart) | 0 | 11-01-2005 12:05 |
Alcatel 512 Unlocking Problem | hamidtele | BF, BG, TH, BHx Series | 2 | 09-13-2003 08:11 |
alcatel 311after unlock problem .warning sos calls onlly HELP!!! | ssulkaa | BF, BG, TH, BHx Series | 1 | 09-26-2002 02:35 |
