12-17-2017, 15:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | want to repair sc6533g imei any way to do it???? rda 1.06 module fail to write Start at : [17-12-2017 / 19:23:25] Operation : Factory Area Rebuild [Repair IMEI] Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Phone not found Finish at : [17-12-2017 / 19:23:56] Start at : [17-12-2017 / 19:24:00] Operation : Factory Area Rebuild [Repair IMEI] Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : CCCCCCCC Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! Finish at : [17-12-2017 / 19:24:20] |
12-17-2017, 15:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Check here & many more on this forum use search button. http://forum.gsmhosting.com/vbb/12846389-post3.html |
The Following 3 Users Say Thank You to Kirumira For This Useful Post: |
12-18-2017, 10:06 | #3 (permalink) |
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | After Repair Still IMEI 000000000 Operation : Identify [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : SC6533 [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : ili9163c/gc9102/gc9105/st7735r/HT2018 [7] : byd3A01/gc6133/gc6123/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2017-05-15_15:53:12 [12] : HA001_128160_1803G_SNOWMAX_EnHiTaBeGu_R47994 Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Repair Security Items [ v1.01 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! LookUp for SECURITY Verify SECURITY Old Device Security Info : New Device Security Info : IMEI[1] : 869276027808530 IMEI[2] : 869276027808548 Repair Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following User Says Thank You to CRM For This Useful Post: |
12-18-2017, 11:44 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | We had found same samples with problems and all will be fixed in near 2-3 days with new features and models. |
The Following 6 Users Say Thank You to JayDi For This Useful Post: |
09-25-2018, 10:41 | #5 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: KPK Age: 34
Member: 2304199 Status: Offline Sonork: 100.1656573 Thanks Meter: 203 | Quote:
The Following User Says Thank You to zebafridi For This Useful Post: |
