08-29-2010, 08:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | Alcatel 208 tp/tx here !!MEDTECHGSM!! thanks button if-------- big up kfkevin he was talking about this here----- http://forum.gsmhosting.com/vbb/f296...-boot-1075572/you can compare which's more easier |
The Following 5 Users Say Thank You to medie For This Useful Post: |
08-30-2010, 07:02 | #3 (permalink) | |
Member: 181277 Status: Offline Thanks Meter: 84 | instruction Quote:
nothing changed, what they did on this new hardware, is to cut tx, so you just loop tx where you see that wire according to image ( or you can call it test point) | |
The Following User Says Thank You to medie For This Useful Post: |
08-30-2010, 09:42 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | THANKS MEDIE,TESTED ON FIVE SETS WORKING FINE HERE IS LOG; module v3.55 Device: Alcatel-208A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:48B8:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 76G provider: 208X-2ARGTE8 customization: CM76CE80 customization: XM76CE80 TCL-ID identification done rom info structure: 2nd [standard] type TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM76CE80 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-208A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W 08_36_SP1_V28_F1__system_log__00000000_20100830-013418.B0X.bin Finished, time used: 2 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to KYEJUSA For This Useful Post: |
08-30-2010, 11:54 | #5 (permalink) | |
Thanks a lot for explanation ! If you still have 208 on hands, please, try to make more big photo so it will be completely clear for any beginner. Thank you ! | |
08-30-2010, 12:43 | #6 (permalink) |
Member: 181277 Status: Offline Thanks Meter: 84 | Cool, i will!!! when i get time but any one can enlarge it. Last edited by medie; 08-30-2010 at 12:48. |
08-30-2010, 12:57 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thanks ! Here is little bit modified picture: Could you, please, tell me exact RJ45 pin number what should be connected to PCB point, is it RJ45-pin-2 or RJ45-pin-3 ? |
solution for all nokia is here | elektron code ECS | GSM Mobile Links | 3 | 07-30-2012 07:34 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
Unlock all locks all phones *HERE* | manfred | GSM Mobile Links | 0 | 02-19-2000 10:50 |
buy your GSM here | midlandcellular | Main Sales Section | 0 | 09-04-1999 17:14 |
