01-07-2011, 15:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Croatia,Varazdin
Member: 33901 Status: Offline Thanks Meter: 5 | alcatel 255 COM5 [VCP0] selected module v3.71 Device: Alcatel-S255X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:652D:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.0E398 D7D.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_C44DA16F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 0E398D7D rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 6FA14DC4 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 96D provider: 255X-2ATEHR1 customization: CP96DW70 customization: XP96DW70 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP96DW70 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->087C03E4 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S255X__system_log_0E398D7D_C44DA16F_20110107-154906.B0X.bin Finished, time used: 2 min 55 sec Remove/Install battery now ! any help? BR |
01-14-2011, 08:40 | #4 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | same cable at ot s320 and it work perfectly |
The Following User Says Thank You to GFTELECOM For This Useful Post: |
01-14-2011, 13:06 | #5 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
02-17-2011, 22:28 | #6 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: france
Member: 901614 Status: Offline Thanks Meter: 104 | Quote:
press Repair security area to resolve the problem of security and re-unlock it B.R bR Hichman1 | |
The Following User Says Thank You to hichman1 For This Useful Post: |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
Alcatel BE$ pinouts | GSM Coolhawk | Alcatel & TCL Old Models | 0 | 12-08-2001 15:44 |
NOKIA, ALCATEL EEprom site | Orbital - GSM | GSM Mobile Links | 0 | 04-09-2001 10:31 |
Alcatel One Touch cable needed!!! | tati | Alcatel & TCL Old Models | 0 | 05-17-1999 22:05 |
