Old 05-18-2011, 13:26   #1 (permalink)
Member: 1158839
Thanks Meter: 127
Alcatel 305x after unlock , when pres buton show alcatel and power off???
COM11 [VCP0] selected
module v3.62
Device: Alcatel-305X, 305A
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:BAA7:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F2977 5C0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_D80CC03B].rpl
New firmware found (v.3.62, database date: 01.10.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: F29775C0
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, 3BC00CD8
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 167
provider: 305X-2FMPBA1
customization: CP16CV12
customization: XP16CV12
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->08632014
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A__system_log_F29775C0_D80CC03B_20110518-142157.B0X.bin
Finished, time used: 3 min 28 sec
Remove/Install battery now !
Old 05-18-2011, 13:32   #2 (permalink)
Member: 1158839
Thanks Meter: 127
what to do now????????????????????
Old 05-18-2011, 13:55   #3 (permalink)
Member: 1158839
Thanks Meter: 127
ok solved
module v3.89
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.F29775C0 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_D80CC03B].rpl
TCL-ID detection...
device-id: F29775C0
rom info ver: 05
version: 167
TCL-ID is present
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35776903951114
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_F29775C0_D80CC03B_201 10518-145356.B0X.bin
Finished, time used: 4 min 6 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 05-19-2011, 12:38   #4 (permalink)
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 273
but how did you repaired it with flash or ffs/eeprom ?
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
For Jefferson -6110 goes off itself sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-19-1999 21:28
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.17016 seconds with 9 queries
